Hi. I've been really confused about something. I hope you guys would be able to help out with this. I have made copies of the DVDs that I own and have shrunk them, to fit into a regular DVD-R, not dual layer. I am going to use Ashampoo Burning Studio 10 to burn the created image files. My DVD burner is a Plextor PX-880SA. So, my main confusion is, what speed should I burn these image files using this burner, DVD-Rs, and Ashampoo? Thanks for any help with this.![]()
First: I would use imgburn to burn images.
2nd: Use good media, as in Taiyo or Verbatim (good verbatim, not the crap media)
3rd: start with a burn speed of 12X (half the rated speed, see how the buffer fills up.
Also, update the firmware for the drive, it's a Plextor, and that matters.
Also, It's likely not a true Plextor, as they sourced them out awhiile back.
It was bad enough to make me stop buying them - last I heard, they were Lite-On drives.
You'd know the difference if you had your hands on one of the originals.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Confusion about Upscaling DVD player Resolution
By searchlight in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Aug 2011, 19:36 -
VHS to DVD help required (some confusion)...
By takearushfan in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2011, 19:28 -
Convertng DVD to WMV with AutoMKV - Output Resolution confusion
By mobon in forum Video ConversionReplies: 3Last Post: 16th Jan 2010, 07:17 -
Samsung DVD-V9800 region hack confusion, misunderstanding?
By AlbertTheSon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2009, 19:42 -
DVD resolution problems / confusion
By Laurels in forum MacReplies: 2Last Post: 5th Jun 2008, 03:57
