    Nov 2009
    I have a HD media player (Popcorn Hour C-200) and a few pc's that are using a Panasonic Ethernet adapter http://www2.panasonic.com/consumer-electronics/shop/Computers-Networking/IP-Networking...702#tabsection. They are also using a LINKSYS EZXS55W 10/100Mbps network switch. Would I be better of with N wireless usb adapter and using a NETGEAR GS605 10/100/1000Mbps giabit switch? I am getting a http://www.newegg.com/Product/Product.aspx?Item=N82E16833122326&Tpk=Netgear%20N600%20W..._-NA-_-NA-_-NA. I am having issues player HD movies with my HD media player through Panasonic Ethernet adapter and LINKSYS EZXS55W 10/100Mbps network switch. I have a cable IP with 30mbps connection.
    Mar 2014
    antananarivo
    I came accross a very interesting website with more info on this product :http://www.directindustry.com/industrial-manufacturer/ethernet-converter-74860.html
  3. Powerline ethernet adapters??? For VIDEO??? No Freaking Way in Hell. Wired gigabit would be best, N-class wireless next. I would use two paper cups and some string before I would go with a powerline adapter setup.
    Who is this "they" you are speaking of with a 10/100 switch? Is this equipment YOU are using, or does this not apply at all to your situation? Use a gigabit switch, even if your wiring doesn't support it, which I don't think powerline adapters do. Not sure, and don't care, use a gigabit switch anyway.
