  1. AccountKiller
    Nov 2010
    AccountKiller
    AccountKiller
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I put my media in paper sleeves inside Ikea slide-out CD wooden storage boxes....and there is no such thing as archival grade media.
  3. Banned
    Freedonia
    Yes, "Archival Grade Media" is an unsupported claim. In fact, my very limited experience with such on the CD-R side is that it may actually be somewhat inferior to cheaper run of the mill CD-Rs. The same is probably true of the DVD "Archival Grade Media" but I never bought any to test.
    Using good quality media is your best bet. This means Verbatim and Taiyo Yuden. Verbatim makes no such claim but I have a personal hunch that their AZO dye may have somewhat superior lasting properties. Again, Verbatim does not claim this and that is only my opinion. Keep your discs away from temperature extremes. If it's anything you really can't live without you'll need multiple copies preferably stored at different locations (ie. you could have a friend put some copies in a closet in his house). You might also want to look into making PAR recovery files and storing those on separate media for anything you really can't live without.
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    A ReadyNAS NV+
  5. AccountKiller
    Nov 2010
    AccountKiller
    AccountKiller
  6. Member classfour's Avatar
    The Heartland, United States
    Stone tablet - if the DVD media doesn't work.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by rcvalle View Post
    I opened the Ikea website and haven't found the product to which you referred. Can you send the link?
    Sadly they were discontinued several years ago.....at least in Europe. The short product number was 14158.
  8. AccountKiller
    Nov 2010
    AccountKiller
    AccountKiller
