    Aug 2010
    Brazil - São Paulo
    I'm trying to burn an avi file (xvid) to watch on dvd but the same is with 1280x532 and the DVD player always says 'unsupported format', so I reduced it to 600x336 and run perfectly, is there any way to run it in 1280x532?
    Media info of this file:
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 27mn
    Bit rate : 2 360 Kbps
    Width : 1 280 pixels
    Height : 532 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.145
    Stream size : 1.45 GiB (92%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    Nope. Most divx dvd players do not support higher resolutions than around 720x576.
