Hi,
I've done a quick scan through the forum but I'm a little confused as there is so much there!
I have an mpg (less than 4gb) which I created with TMPGenc Xpress. I'd like to convert it to vob files to be dvd compliant, and I was wondering if there are any freeware programs to do this without re-encoding? Smart encoding I think its generally called?
I have Pinnacle Studio 10. Would this do it? Ive always been unsure if that has smart encoding. If not I need something cheap (IE FREE!).
Thanks for any help.![]()
If you don't menus use simple dvd creator. If you want menus use dvdstyler or guifordvdauthor. More authoring tools ordered by free, https://www.videohelp.com/tools/sections/authoring-dvd?orderby=Type
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Any free tool for batch conversion from VOB/MPG to DV AVI
By arminio in forum DVD RippingReplies: 5Last Post: 15th Oct 2009, 16:14 -
problems with VOB to MPG conversion
By Created78 in forum Newbie / General discussionsReplies: 6Last Post: 21st Jul 2009, 12:20 -
VOB to MPG Conversion: Can't get the right software!
By GeekyChocolate in forum Video ConversionReplies: 12Last Post: 5th Mar 2009, 23:52 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
