Trying to reinstall AvsEdit 1.1.1.3 on an new machine, I get 'please install .NET framework 1.1 first'. OS is XP Sp3, the machine has .NET 4.0, and up to now I thought those frameworks were cumulative. Do I need to install 1.1 after all? Help most appreciated.
Leo
Please redirect if this is the wrong forum.
Thanks both of you for your help.
@ guns1inger: installing 1.1 did it.I seem to remember however, that in the former version the preview function was easier to work with and showed the frame #. Anything I overlooked?
@ alanHK: I unpacked AvsPmod, but it simply does nothing.
Error Traceback (most recent call last):
File "run.py", line 1, in <module>
import os, sys
ImportError: No module named os
What is missing?
Thank you again -
To install, you simply unzip the file and then run "AvsPMod.exe" (or create a shortcut for that and put it on your Start menu.).
You should have a main folder (AvsPMod, or whatever you want to call it), and 4 subfolders:
help
lib
macros
src
tools
In particular, that error means it can't find files in "lib".
So did you create the folders, or extract all files to the same folder?Code:Directory of P:\AvsPmod\lib 23/12/2008 04:11p 31,232 _ctypes.pyd 23/12/2008 04:11p 19,968 _socket.pyd 23/12/2008 04:11p 231,936 _ssl.pyd 23/12/2008 04:11p 32,768 bz2.pyd 10/04/2010 12:00p 867,324 library.zip 23/12/2008 04:11p 7,680 select.pyd 23/12/2008 04:11p 142,848 unicodedata.pyd 19/09/2006 05:26p 77,312 wx._controls_.pyd 19/09/2006 05:26p 115,200 wx._core_.pyd 19/09/2006 05:26p 61,440 wx._gdi_.pyd 19/09/2006 05:26p 74,240 wx._misc_.pyd 19/09/2006 05:26p 43,520 wx._stc.pyd 19/09/2006 05:26p 65,024 wx._windows_.pyd 19/09/2006 04:52p 199,168 wxmsw26uh_stc_vc.dll 19/09/2006 04:51p 2,033,664 wxmsw26uh_vc.dll
Stupid me unzipped everything to the same dir.
At the same time this answered my 2nd question, as I got back the preview function with frame count.
Thank you.Last edited by Leo48; 21st Nov 2010 at 04:44.
Which version of microsoft .NET Framework should I keep out of these three?
By mudh in forum ProgrammingReplies: 4Last Post: 10th Oct 2011, 12:51 -
Hauppauge WinTV and MS Net .Framework
By ionavideo in forum Capturing and VCRReplies: 0Last Post: 2nd Jun 2010, 05:29 -
Net Framework...which version should i install?
By ricardouk in forum ComputerReplies: 4Last Post: 18th Jan 2010, 13:07 -
Help - Can't download .net Framework 2.0
By nhbfan12345 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Aug 2008, 16:30 -
Request For Comments: .NET framework
By Midzuki in forum ComputerReplies: 25Last Post: 29th Sep 2007, 14:07
