I convert MKVs to WMV-HD. I use Windows 7 Ultimate x64, TMPGEnc Xpress 4.0 and Popcorn MKV AudioConverter for DTS-to-AC3.
I had Popcorn open earlier (first time in a while) to attempt to convert a movie but I got numerous errors. I tried various configurations but they all failed on the mkvmerge.exe step. So I attempted to open directly in TMPGEnc and just try converting it as a DTS. But then Xpress won't even open MKVs. No fancy error, just says it's unable to open the file. It fails to open files that I've converted in the past, as well.
Any idea what's going on? I've tried reinstalling the main codec I use (DivX) and that didn't nothing, as well as reinstalling MKVtoolnix and Popcorn. I'm pretty sure it worked after my latest reformat (in which I had to replace my C: drive), but I'm not 100%. All I know is that my configuration has NOT changed since I last converted.
Any help would be greatly appreciated.
Check what's inside your mkv's with GSpot or mediainfo.
If the video is h264, and you're converting to wmv, then re-installing a DivX codec won't have any relevance. -
I've got MediaInfo installed, but I'm not sure where to look for the codec.
Under container and general info it says:
1 video stream: AVC
Is that it? I see no mention of h.264. What's my solution? CoreAVC? I've never had it on before though, and I've never had an issue like this until now.
Thanks for the reply. -
Don't know what the problem was, but a reformat fixed it. Using the same AC3Filter/DivX combo and it's working fine.
Odd.
DVD Shrink won't recognize Nero(New PC with Windows 7 64 bit)
By Jonathan in forum DVD RippingReplies: 19Last Post: 1st Jun 2011, 08:41 -
Windows Movie Maker Won't Open
By kerrex_2006 in forum ComputerReplies: 4Last Post: 29th Apr 2011, 03:08 -
Windows Media Player won't recognize srt file when multiplexed into an mp4?
By MR 3 in forum Video ConversionReplies: 2Last Post: 22nd Oct 2009, 11:44 -
Some MKVs Will Not Play from FW800 External HDD in Mac, Works in Windows
By encodedprocess83 in forum MacReplies: 1Last Post: 11th Dec 2008, 08:26 -
MKVs Won't Play from External HDD
By encodedprocess83 in forum Software PlayingReplies: 4Last Post: 10th Dec 2008, 01:02
