    Feb 2002
    Hi folks.
    I am piecing together the method under OS X for SVCD creation. Everything looks like it may be in place (kudos to rnc!), but there's a problem. Mediapipe quits every time I start the encoding.
    I have a feeling that there is a problem with the mpeg2encoder pipe itself. I didn't compile it because it seemed the package downloaded with a completed pipe. Does anyone know what is going on, or if there is a compiled (correct) version of the mpeg2 pipe around?
    Thanks.
  2. The pipe is only the interface between MediaPipe and the encoder.
    The endoder itself is a binary located in /usr/local/bin of the root.
    It will only be put there by compiling and installing, (requires Dev Tools).
    If you can't get past this point, email me.
    Ross, aka RNC
