Hello,
I have a DTS audio file at 44khz. I have my DTS enabled surround amplifier via toslink cable.
When I try and play the file via VLC, the audio plays but it doesnt appear to play in DTS. The amplifier display shows PCM as the file output. When I try and play the file in WMP12 or windows media player classic I just get static.
I have a DVD that has a DTS soundtrack and this plays DTS ok on any media player.
Is there any way to get this working?
I have read various things about AC3 filters and different codecs but am yet to find an answer on how to do it.
Anyone help?
Thanks.
your sound card may have to be set to spdif out only.
[edit] are you sure your amp supports 44.1khtz dts? older ones only decoded 48khtz.--
@hungledink
Hi,
1.your amplifier shows 'pcm' or 'lpcm' 'cause yout dts file is already decoded and sent as lpcm or pcm 5.1 by VLC.
2.if you want to see the 'dts' blinking in your amplifier you must feed him with a so called 'bitsream' and your amplifier would do the decoding.....
For this purpose i suggest:
Install ffdshow[under output tab enable the dts pass-through]....disable ac3 filter...so automaticly when you play the dts file in wmp,ffdshow starts too.
Have a nice day,
M
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
Unable to play dts on new transcoded file
By jones24 in forum AudioReplies: 6Last Post: 26th Feb 2010, 10:36 -
Can PS3 play DTS file ???
By luckymefella in forum Media Center PC / MediaCentersReplies: 4Last Post: 5th Nov 2009, 17:48 -
Play/Convert .DTS??
By merciscool in forum MacReplies: 3Last Post: 24th Aug 2009, 14:24
