Following samples may be useful for VideoPlayer's, VideoEncoder's and VideoEditor's Developers for stream selection. I will try to keep file size below 200mb, RapidShare Free Account file size limit 200mb. In case if anyone need larger sample, let me know here, i will upload in parts in RAR format.
DOWNLOAD LINK
http://rapidshare.com/files/431855416/Multi_Audio_n_Subtitles_Sample_1.vob
General
Complete name : Multi_Audio_n_Subtitles_Sample_1.vob
Format : MPEG-PS
File size : 83.8 MiB
Duration : 2mn 14s
Overall bit rate : 5 226 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 2mn 14s
Bit rate mode : Variable
Bit rate : 3 714 Kbps
Nominal bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Bits/(Pixel*Frame) : 0.448
Stream size : 59.4 MiB (71%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Duration : 2mn 14s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : -136ms
Stream size : 7.18 MiB (9%)
Audio #2
Format : AC-3
Duration : 2mn 14s
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 6.16 MiB (7%)
Audio #3
Format : AC-3
Duration : 2mn 14s
Bit rate : 384 Kbps
Bit depth : 16 bits
Audio #4
Format : AC-3
Format profile : Dolby Digital
Duration : 2mn 14s
Bit rate : 192 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Video delay : -72ms
Stream size : 3.08 MiB (4%)
SAMPLE 2
DOWNLOAD LINK
http://rapidshare.com/files/424737190/VideoSampleClip.mpeg
General
Complete name : VideoSampleClip.mpeg
Format : MPEG-PS
File size : 73.0 MiB
Duration : 2mn 36s
Overall bit rate : 3 909 Kbps
Video
Format : MPEG Video
Duration : 2mn 36s
Bit rate : 2 807 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : Component
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.339
Stream size : 52.3 MiB (72%)
Audio #1
Format : AC-3
Duration : 2mn 36s
Bit rate : 448 Kbps
Bit depth : 16 bits
Video delay : -78ms
Stream size : 8.36 MiB (11%)
Audio #2
Format : AC-3
Duration : 2mn 36s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -78ms
Stream size : 3.58 MiB (5%)
Audio #3
Format : AC-3
Duration : 2mn 36s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -78ms
Audio #4
Format : AC-3
Duration : 2mn 36s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -78ms
Text #1
Format : RLE
Format/Info : Run-length encoding
Duration : 2mn 33s
Video delay : 751ms
Text #2
Format : RLE
Duration : 2mn 33s
Video delay : 751ms
Text #3
ID : 224 (0xE0)-DVD-2
Format : EIA-608
Muxing mode : DVD-Video
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Text #4
Format : RLE
Text #5
Format : RLE
SAMPLE 3
download links:
LINK-1
1) http://rapidshare.com/files/424560778/video_sample_ac3_n_pcm_with_sub_.vob
alternate link
2) http://rapidshare.com/files/424560883/video_sample_ac3_n_pcm_with_sub_.vob
Media Info:
General
Complete name : video_sample[ac3 n pcm with sub].vob
Format : MPEG-PS
File size : 114 MiB
Duration : 3mn 22s
Overall bit rate : 4 729 Kbps
Video
Format : MPEG Video
Format settings, GOP : M=3, N=15
Duration : 2mn 33s
Bit rate : 2 651 Kbps
Nominal bit rate : 8 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.256
Stream size : 48.4 MiB (42%)
Audio #1
Format : AC-3
Duration : 2mn 33s
Bit rate : 448 Kbps
Bit depth : 16 bits
Video delay : -48s 754ms
Stream size : 8.21 MiB (7%)
Audio #2
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Duration : 3mn 22s
Bit rate : 1 536 Kbps
Bit depth : 16 bits
Video delay : -48s 839ms
Stream size : 37.1 MiB (32%)
Text#1 : enSUB.srt
SAMPLE 4
DOWNLOAD LINK
http://rapidshare.com/files/431868665/Multi_Audio_n_Subtitles_Sample_2.vob
General
Complete name : Multi_Audio_n_Subtitles_Sample_2.vob
Format : MPEG-PS
File size : 112 MiB
Duration : 2mn 35s
Overall bit rate : 6 078 Kbps
Video
Format : MPEG Video
Duration : 2mn 34s
Bit rate : 4 677 Kbps
Nominal bit rate : 7 500 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.564
Stream size : 86.1 MiB (77%)
Audio #1
Format : AC-3
Duration : 2mn 35s
Bit rate : 448 Kbps
Bit depth : 16 bits
Video delay : -30ms
Stream size : 8.29 MiB (7%)
Audio #2
Format : AC-3
Duration : 2mn 35s
Bit rate : 448 Kbps
Bit depth : 16 bits
Video delay : -30ms
Audio #3
Format : AC-3
Duration : 2mn 35s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -14ms
Stream size : 3.55 MiB (3%)
Audio #4
Format : AC-3
Duration : 2mn 35s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -14ms
Text #1
Format : RLE
Video delay : 1s 768ms
Text #2
Format : RLE
Text #3
Format : RLE
Text #4
Format : RLE
Text #5
Format : RLE
Text #6
Format : RLE
Text #7
Format : EIA-608
In case of need of more samples. Request Here.
Hi, the links are dead, is there any chance of re-uploading? I need such files for testing.
Thanks -
Sorry!
i guess it was my mistake to select wrong file-sharer, and tiny sized files are deleted somehow without or no activities since long.
I created those samples to test various video programs including various converters and players and provided links here with a hope it might be useful to someone.
Samples were nothing but chopped-vobs or re-muxed vobs from original DVDs,
I guess any one can chop and generate similar samples from original DVD.
I will try to upload one or two back here again without any time limit.
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 14:21 -
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 09:17 -
Multiple audio, subtitles, OGM, MKV & RMVB issues
By bkfng in forum ffmpegX general discussionReplies: 12Last Post: 16th Jan 2011, 23:05 -
mkv - deleting multiple audio tracks & subtitles - then convert to avi
By fme008 in forum Video ConversionReplies: 2Last Post: 24th Mar 2009, 06:12 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
