    Sep 2010
    Trivandrum
    Hi friendz,
    I have got two mkv files which were splitted from the source file.The first file was edited and joined with the second one using mkvmerge.no errors were shown and the files were muxed sucessfully but when i played it(VLC ) .it plays as two video files GOM & KM player plays it but doesn't play the merged part.
    First mkv file(edited file)
    General
    Complete name : C:\Documents and Settings\Muzammil\My Documents\Fight Club (1)-002.mkv
    Format : Matroska
    File size : 24.1 MiB
    Duration : 1mn 4s
    Overall bit rate : 3 107 Kbps
    Encoded date : UTC 2010-11-19 11:30:22
    Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1mn 4s
    Width : 1 280 pixels
    Height : 528 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Writing library : x264 core 92 r1510 33d382a
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=5 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Codec ID : A_AAC
    Duration : 1mn 4s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Second mkv file(same as source file)
    General
    Complete name : E:\Films\Fight Club (1999)\Fight Club.mkv
    Format : Matroska
    File size : 2.38 GiB
    Duration : 2h 19mn
    Overall bit rate : 2 448 Kbps
    Encoded date : UTC 2010-11-16 10:09:34
    Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
    Writing library : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, ReFrames : 6 frames
    Format settings, GOP : M=6, N=25
    Duration : 2h 19mn
    Nominal bit rate : 2 000 Kbps
    Height : 528 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.123
    Writing library : x264 core 104 r1703 cd21d05
    Encoding settings : cabac=1 / ref=6 / deblock=1:0:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=2.00:1.10 / mixed_ref=1 / me_range=25 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=3 / sliced_threads=0 / nr=25 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=65 / rc=2pass / mbtree=1 / bitrate=2000 / ratetol=1.8 / qcomp=0.30 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.30
    Audio
    Format : AAC
    Format profile : LC
    Format settings, SBR : No
    Codec ID : A_AAC
    Duration : 2h 19mn
    Is it because that i have edited the first file the merged file doesn't play normally. i don't want to re-encode two splitted files and merge them.anyways to make the first mkv file as it were before and mux it then maybe video will play normally.sorry if i have posted too much information .I have got help whenever i wanted it. Hope this time also will be the same.
    Mny thankz.
    Did you choose append in mkvmergegui? If you use add it will make a mkv with two video tracks. See http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#basics
    Or you can also try avidemux, open mkv, append the other, save as a new mkv.
    Sep 2010
    Trivandrum
    thankz baldrick for the quick replay.i'm sure i have appended it not the add option.haven't tried avidemux .i'm gonna use it and will inform the results soon.
    Sep 2010
    Trivandrum
    tried avidemux but the resulted mkv don't play the merged part(second file).any other way ??
    Sep 2010
    Trivandrum
    come on guys .you are all video super freaks !!at least tell me whether it is possible or not
