I realized when watching my copy (backed up by VOB2MPG PRO) of Red Dawn that I don't understand Russian very well!
So, for those DVDs that use the encoded subtitles (or subpictures, however they are called), where the English subtitles are not already part of the video, VOB2MPG PRO is basically useless!
Any chance of getting subtitles rendered to the MPG output file in an upcoming version of VOB2MPG?
Thanks very much!
	Rendering "into" the mpeg video stream is not going to happen as then we are talking about video encoding.... there are plenty of programs out there for that.
 I am working on extracting subtitle streams to VobSub format. Then, depending on what you are doing with the mpeg, it becomes usable for viewing, authoring etc...
 Also, the subtitles - if they exist in the DVD - are maintained in the mpeg currently. See: https://forum.videohelp.com/threads/319805-VOB2MPG-Subtitles
 So the question is what are you using to play the mpegs? Perhaps one of the above will work for you.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
  Unable to install VOB2MPG or VOB2MPG PROBy tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53
  IfoAR2WS Feature RequestBy TheArtfulDodger in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 13:36
  feature request: Vob2mpg pro command line option for audio stream selectionBy Ahimoth in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Sep 2009, 06:42
  New Feature Request - DVD TitleBy noyou in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Sep 2008, 08:25
  Feature request - auto titlesBy Neil Herber in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th May 2008, 13:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
