    Nov 2010
    I´ve searched for a long time
    for a converter/encoder that are using nandub to demux the video and audio togheter
    but I have never found it.
    I have seen in many codes of movies and tvrips that the writing application is nandub,
    for an exempel:
    Format                           : AVI
    Format/Info                      : Audio Video Interleave
    File size                        : 700 MiB
    Duration                         : 1h 33mn
    Overall bit rate                 : 1 048 Kbps
    Writing application              : Nandub v1.0rc2
    Writing library                  : Nandub build 1852/release
    Video
    Format                           : MPEG-4 Visual
    Format profile                   : Simple@L3
    Format settings, BVOP            : Yes
    Format settings, QPel            : No
    Format settings, GMC             : No warppoints
    Format settings, Matrix          : Default (MPEG)
    Muxing mode                      : Packed bitstream
    Codec ID                         : XVID
    Codec ID/Hint                    : XviD
    Duration                         : 1h 33mn
    Bit rate                         : 905 Kbps
    Width                            : 624 pixels
    Height                           : 352 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 25.000 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.165
    Stream size                      : 605 MiB (86%)
    Writing library                  : XviD 1.0.3 (UTC 2004-12-20)
    Audio
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 3
    Mode                             : Joint stereo
    Mode extension                   : MS Stereo
    Codec ID                         : 55
    Codec ID/Hint                    : MP3
    Duration                         : 1h 33mn
    Bit rate mode                    : Variable
    Bit rate                         : 128 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Stream size                      : 87.2 MiB (12%)
    Alignment                        : Aligned on interleaves
    Interleave, duration             : 24 ms (0.60 video frame)
    Interleave, preload duration     : 135 ms
    Writing library                  : LAME3.90.
    Encoding settings                : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
    Or this tvrip:
    Format                           : AVI
    File size                        : 350 MiB
    Duration                         : 43mn 54s
    Overall bit rate                 : 1 115 Kbps
    Video
    Format profile                   : Advanced Simple@L5
    Format settings, Matrix          : Default (H.263)
    Codec ID                         : XVID
    Duration                         : 43mn 54s
    Bit rate                         : 969 Kbps
    Width                            : 640 pixels
    Height                           : 352 pixels
    Color space                      : YUV
    Bit depth                        : 8 bits
    Bits/(Pixel*Frame)               : 0.172
    Stream size                      : 304 MiB (87%)
    Writing library                  : XviD 1.3.0.dev55
    Audio
    Format                           : MPEG Audio
    Mode                             : Joint stereo
    Codec ID                         : 55
    Codec ID/Hint                    : MP3
    Duration                         : 43mn 54s
    Bit rate                         : 128 Kbps
    Bit depth                        : 16 bits
    Stream size                      : 41.9 MiB (12%)
    Writing library                  : LAME3.95
    Encoding settings                : -m j -V 4 -q 3 -lowpass 17.5 --abr 128
  2. Banned
    Freedonia
    Nandub is really old. That's what people were using almost 10 years ago to do Divx encodes. The last update was in 2001. I wouldn't worry about it. If you don't want to pay for the commercial Divx codec then you can try using AutoGK with Xvid. Nandub was designed to get around problems with the ancient original Divx codec that haven't existed in maybe 7 or 8 years now. Nobody should use it now. It's actually inferior to both AutoGK with Xvid and the commercial Divx codec.
    Nov 2010
    Ye I´ve reading many things about nandub but i use it as a muxer to mux video and audio togheter (Never using divx).
    What im looking for is a program that are using it because im tired of using staxrip, avidemux , GK and other programs.
    It seems to mee that the most tvrippers and dvdrippers are using a program that uses nandub to mux but i can´t find it.
    Another reason is that allmost all nandub muxed movies have a bitrate of 128kbps vbr mp3 and in staxrip you allwas get a random bitrate from 105-165 kbps.
  4. Originally Posted by PageDown View Post
    It seems to mee that the most tvrippers and dvdrippers are using a program that uses nandub to mux...
    They aren't. That's just something written in the header and doesn't have to have any relation to what was really used. AutoGK and Gordian Knot, for example, are both using Virtual Dub Mod. And both programs allow you to choose the audio bitrate.
    Nov 2010
    B
    ut do you think that they are using Gk then?
    Quite tired of using StaxRip & GK, do you know any other programs or methods to rip?
  6. Originally Posted by PageDown View Post
    But do you think that they are using Gk then?
    I have no idea what they use. If they're any good they're doing it manually, feeding AviSynth scripts into VDub.
    AviSynth, VDub, BeSweet. Those are about all I use, but there are probably lots of other all-in-one programs.
