Hope you guys can help me out on this one, I have always put my Photos as JPEG files on a CD to play them on my parents TV via a DVD player without any problems, But recently I have scanned some 35mm slides into my PC and then burnt them as a DATA CD and only the first TWO slides will come up on the screen, The rest wont display, This happens on another DVD player too. Has anyone any ideas of what has happened, Its not a bad burn as I have done three now and all are the same.......![]()
Too high resolution? Or are they similar as the other that works fine?
I gues the burned images works fine on your computer. -
Yes they play on PC/LAPTOP fine, I scanned them at different resolutions so that could be the problem, Is there a way to tell what resolution i scanned them at using just the JPEG info. and more importantly is there a program I could use to change the resolution to a more DVD Player friendly value. I really dont want to have to scan them all in again
You could use irfanview to batch copy/convert all to a lower resolution. Keep the originals.
Authoring DVD with embedded jpegs - Help
By RNBzie in forum Authoring (DVD)Replies: 4Last Post: 18th Jun 2011, 10:44 -
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
JPegs don't play in correct order on DVD player
By NichoPhoto in forum Newbie / General discussionsReplies: 12Last Post: 3rd Feb 2010, 07:11 -
DVD playing in standalone player but not on PC
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 09:35
