  1. Okay I have been having problems converting from .avi to mpeg and getting a compliant vcd!
    I learned that seperating the sound then converting worked better for me but I was left with a wave audio file that I can't multiplex together with the mpeg file I created!!
    DO I need to convert the wave file to a mp3 of something??
    PLS HELP!!!!
    THANX!
    exzilerate
  2. You need to convert your wave file to an MPEG1 layer2 audio stream to combine it with your video. To be compliant use a 224 kbps bitrate. TMPGENC can do this or xing encoder as well.
