Hello, everyone.
I would like to know the solution to the following question:
I have two disks:
disk 0 - C: and D: ( 250 GB )
disk 1 - E: F: and G: ( 1 TB )
(Windows XP sp2)
I want to aggregate C: and D: , so disk 0 does'nt have any partition.
But C: has the OS installed.
How can I to do that in the following cases:
a) If it is possible to do the work without to erase XP.
b) If it is not possible what can I do.
Thanks a lot.
Cheers.
Results 1 to 14 of 14
1) grab a copy of GPARTED CD and burn a copy
2) move stuff off D: drive
3) boot CD, reduce D: partition size, expand C: partition size
4) boot Windows
5) move stuff that was on D: to now larger C: drive
6) repeat 2-5 till D: empty
7) boot CD, delete D: partition, expand C: to whole disk -
OK, TJohns. It seems a little confusing but understandable. My drive D: is empty. I think, in my case, I must suppress the points 2), 5) and 6). Or also eliminate points 4) and 5) ?
Thank you very much, TJohns.
hech54 - With disks so great, for me is indispensable to divide them in two or three.
Cheers. -
If D: is empty, just delete D: and expand the C: partion size to full disk in GParted. Backup any critical data first.
When finished it is a good idea to defrag your C: drive in XP. The files will be scattered.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I downloaded GPARTED and burned it in a CD.
The CD has 4 folders and 2 files ( COPYING and Gparted-Live-Version ) no .exe?
How can I execute GPARTED? -
GParted does what Partition Magic used to do without the constant $upgrades for NTFS and large drives. It is free from a simple Linux boot.
Hopefully you will not loose the entire contents of both drives due to partition instability related to GPartEd. Been at least 2 or 3 months since one of those showed up.
You can not fully Avoid partitions, you have to have at least ONE. What you can avoid, and I absolutely recommend, is not to MESS WITH a partition structure in ANY WAY, SHAPE, or FORM. In the future, keep your partition structure as simple as possible. -
I performed the operations with Gparted and it is everything well done.
Thank you, everybody.
Cheers.
how do i copy DVDRAM disks to a pc hard drive (retaining exact quality)
By mnbvc in forum DVD RippingReplies: 19Last Post: 23rd Sep 2015, 15:18 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Dropsies-What's the worst you've dropped a hard drive onto a hard surface
By Seeker47 in forum ComputerReplies: 6Last Post: 11th Jun 2008, 13:53 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 14:48
