Hi all ... Well I have all these camera recorded MP4 video files which I'd like to re-encode into XviD AVI format ... I normally use VirtualDub for all video related procedures but VirtualDub doesn't by default support MP4's (I know there are workarounds but they dont product good results for me) ..
So I have tried a few small 'format conversion' program for converting MP4 to AVI, but they all give choppy/blocky AVI videos .. The results videos have parts in them which remain 'constant' for 2-3 seconds and then suddenly change (going from one keyframe to another directly) ..
I need a tool/program (free or otherwise) which can give good outputs and supports batch conversion (since I have a lot of MP4s and would like to run the same job on all videos) ..
Any recommendations ?
Why? But seriously, use Xmedia Recode just play around with the settings to get the best possible quality. You can add all the projects and it will do one after the other.
If you concern with quality, use H264 codec instead. XviD is dying -
Just curious, since I use Virtualdub (with Quicktime plugin) to convert MP4s without issue: could you be more specific about the not-good results you're getting? Maybe it's easily fixable.
Best,
Calidore -
http://sourceforge.net/projects/mp4cam2avi/
Lossless converting from MP4 to AVI -
ImTOO Video Converter 6. The trial version is full featured for videos under 3 minutes.
http://www.imtoo.com/dvd-ripper.html?utm_source=newsletter&utm_medium=email&utm_conten...ign=dvd-ripper
creakndale -
VirtualDub with the DirectShow plug-in works great for me - MP4 and use ffdshow to recompress.
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 12:32 -
Looking for a good authoring software that support using MP4 files to DVD
By LegendaryGamer in forum Authoring (DVD)Replies: 4Last Post: 10th Mar 2010, 16:04 -
What software is good for converting to DivX..?
By Karel Bata in forum Video ConversionReplies: 6Last Post: 8th Dec 2009, 12:36 -
Reccommend a good encoder from avi/mkv to mp4
By ir0n_ma1den in forum Video ConversionReplies: 2Last Post: 10th Jun 2008, 19:11 -
converting .mp4 to avi
By georgeyboy in forum Video ConversionReplies: 3Last Post: 6th Nov 2007, 20:13
