I have a HD PVR and I am recoding using the Xbox 360 mode (MP4, H.264) and have been converting my files using a freeware program MP4cam2Avi which changes the MP4 file to a AVI, so I can edit with Movie Maker. So far this is the best and fastest converter to avi I have found. All other converters show a significant loss in quality (HD quality needed) and for this larger file (approx: 5 hours HD) I am trying to convert, it gives me a error saying "Moov Atom not Found" also gives another error "Threading Error". Is there any way to fix the Moov error or another freeware program that will give me quality avi conversion.
That error has something to do with your Quicktime player. When you take an Apple "update" it has very little benefit to you, it's mostly Apple trying to re-jigger the player so your other programs can't use it. If you pay the fee and upgrade to "Pro", this issue disappears.
Apple is trying to infiltrate Windows via iTunes and the other handful of stuff they take the liberty to install and they can't even give us a reach-around on the Quicktime player.
Bottom Line: "Moov Atom iis some kind of Applespeak.Last edited by budwzr; 17th Nov 2010 at 17:06.
Well, when I use the same type of file with the converter it converts it no problem and with good quality. I have a PC and am not to knowlegable about the role quicktime plays with this type of conversion if any(to me I didn't think it did). I thought that maybe because of how big the HD MP4 file was it might have been giving this error. It is just off to me that it would convert other files with no problem and fast, but this file it shows the error. I was expecting to wait a while for the file to convert but I just have been searching forever about this lol. Thanks for the reply.
Thanks again, kind of stinks it wont convert and I am to cheap to pay lol. Lose _ Lose situation
I was doing some research and found this at the mp4cam2avi website:
"Unlike many converting apps, MP4Cam2AVI doesn't require QuickTime or any codecs to work, it performs all the job itself."
Also, the author invites users to contact him for issues.
Seems like mp4cam2avi is a remuxer, that's why it seems so fast. There are others out there, AVIDemux comes to mind, look in the tools section.
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
MKV (h.264 file) conversion to AVI or MP4
By killwill169 in forum MacReplies: 43Last Post: 12th Aug 2009, 18:35 -
What is the best program to convert from H.264 mp4 to H.264 avi?
By Stealth3si in forum Video ConversionReplies: 6Last Post: 15th Sep 2007, 10:11 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
