Results 1 to 12 of 12
  1. Hi,
    I have been trying for some time now to compress some videos that I have recorded using a photo camera (Canon SD870IS). Every time I tried either the video was bad or the sound was bad. I have searched the tutorials, but I did not find an article that fitted my problem or maybe I didn't realize that those were helpful.
    All I wanted was to keep the quality but decrease the file size - if that is possible. Could you please recommend an application or some tutorial that could help me decrease the file size?
    Thank you,
    Lucian
    This is the media info from one of the files:
    General
    Complete name : D:\Poze\munte\MVI_0833.AVI
    Format : AVI
    File size : 85.5 MiB
    Duration : 45s 367ms
    Overall bit rate : 15.8 Mbps
    Mastered date : Thu Aug 28 13:32:10 2008
    Writing application : CanonMVI06
    Video
    Format : M-JPEG
    Frame mode : 8
    Codec ID : MJPG
    Bit rate : 15.1 Mbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 30.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 1.639
    Stream size : 81.7 MiB (96%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Unsigned
    Codec ID : 1
    Codec ID/Hint : Microsoft
    Bit rate mode : Constant
    Bit rate : 705.6 Kbps
    Channel(s) : 1 channel
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 3.82 MiB (4%)
    Interleave, duration : 986 ms (29.59 video frames)
    Interleave, preload duration : 1000 ms
    Mar 2008
    Try AVIDemux.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You have 640x480 MJPEG frames at 30fps.
    Windows Movie Maker can edit it and convert to wmv so long as you have an MJPEG codec installed.
    http://www.kiva.org/about
  4. I tried Windows Movie Maker and with it the encoded movie looses a lot of quality when comparing with the original.
    I will give AVIDemux a try too.
    I searched the site some more and I found HandBrake which seems to do a good job. Do you think that is a good solution for what I need?
    thank you for your suggestions
  5. Quality will depend largely on what codec you select and how much you ask it to compress.
  6. Member edDV's Avatar
    Mar 2004
    Keep in mind that digital camera MJPEG is heavily intrafreame compressed (~50x) and noisy. Audio is uncompressed low grade 8 or 12 bit PCM mono.
    If you want to compress further some intraframe (Mpeg GOP based) compression may be possible but the noise will make motion detection tricky. Best to use a denoise filter before re-compression. Audio can be compressed to mp2 or ac3.
  7. @edDV: Although what you are saying sounds good, I do not really know how to translate that into facts.
    What you are recommending is to decompress the file using a denoise filter, then compress it back and at re-compression use a mp2-ac3 audio codec, right?
    Could you also tell me what applications could help me do that?
    Thanks a lot to all of you!! I really appreciate all the help
  8. Oops, wrong thread.
    Jul 2009
    Spain
    According to his first post, trynitro's video has a bitrate of 15.1Mbps, with Bits/(Pixel*Frame) = 1.639.
    By my calculations, that's a compression of less than 8x.
    Audio is 16 bit mono.
  10. I agree with Gavino -- if you assume the source is 4:2:0 then it's less than 8x compression:
    640 x 480 * 1.5 (bytes per pixel, 4:2:0) * 30 fps * 8 (bits per byte) / 15,000,000 = ~7.37
    Probably pretty good quality. MPEG 2 or h.264 compression should do pretty well with that unless it's very noisy.
    Jul 2009
    Spain
    if you assume the source is 4:2:0 ...
    That's what I assumed, since it's what the MediaInfo listing reports.
  12. Member edDV's Avatar
    Mar 2004
    I was responding to the typical digital camera using MJPEG for video. MJPEG has been a digital camera shortcut to video using frame based JPEG compression only. This meant they had to over-compress intraframe (no interframe compression). Audio was uncompressed 8 bit PCM (lowest common denominator). I guess they were avoiding MPeg or AC3 patents.
    These newer cams seem to be using higher 15 Mb/s bit rates (thanks to AVCHD pushing flash ram to Level 4-6) and audio is now 16 bit PCM mono. That gives you more usable video bitrate to apply interframe MPeg GOP based compression (MPeg2 or MPeg4 based).
    A camera that captures direct to MPeg (e.g. AVC h.264) will have higher quality per bitrate.
