I have a Protron DVD player model PD-007 in progressive mode, how do I reset it, can't see the menu on screen.
I've never heard of that company. That's probably bad news for you. Most likely it means that it's going to be almost impossible to get good information on the player.
If you have the docs that came with the player it might tell how to reset the player to some kind of default mode, assuming such is possible. Or you could try a search and try to find some sort of Tech Support at the company and ask for help, but this also assumes that there is some kind of easy way to reset the player. Or you could find a friend with an HDTV and hook up the player to that and reset it once you have made the connection. -
Read the info here,i googled and found lots of help on the dvd player.
https://www.videohelp.com/dvdplayers/protron-pd-007/4966I think,therefore i am a hamster. -
Next time you make a post be sure to read the date of the last poster,was 3 1/2 years ago.
Well, he did wait 3 1/2 years after joining to make his first post so it kind of evens out.....
Wait,it's only 8 days after he joined that the last post was sent so his post could have taken him 3 years to send.
Protron PD-DVR100 DVD Recorder
By silkphoenix in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Sep 2011, 12:03 -
setting to capture 30p(progressive mode) from canon HV30?
By yunakokimama in forum Capturing and VCRReplies: 3Last Post: 27th Oct 2008, 01:39 -
How can I reset my Sanyo DVD player?
By 89SDML in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 11:08 -
Progressive Out vs. Film Mode on TV?
By churchie04 in forum DVB / IPTVReplies: 1Last Post: 4th Jan 2008, 21:59 -
PAL Camcorder with Progressive Scan Mode
By ropdoh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Jul 2007, 07:27
