Hi all. I am having a really hard time trying to figure this out. I am trying to add chapters to mkv movie files. I am using mkvmerge GUI and MKV Chapter Creator to create the xml file. You can download and see that software here http://cyb3rh4xter.wordpress.com/mkv-cc/ So I created the xml file i named it chapters. I am not sure if you need to name it something specific. I go to mkvmerge and load my mkv file. Then I load the xml file to the chapter editor and this is what I see http://yfrog.com/mvchaptereditorj Then I get an error when I hit start mux http://yfrog.com/45errorjsj This is frustrating. I just want chapters on an MKV is that to much to ask for lolll
do what the error message tells you-load it via global tab, not chapter editor tab
I know this thread is kinda old and the TC probably have solved his problem.
Anyway, if you haven't and for all of those who end up here after some googling:
There is a new version available that is so much easier to use, the link to it is this:
http://cyb3rh4xter.wordpress.com/mkvc/
using mkvmerge gui
By zoloabc in forum EditingReplies: 8Last Post: 26th Jun 2014, 12:44 -
get chapters from DVD with mkvmerge GUI ?
By lovelove in forum DVD RippingReplies: 2Last Post: 12th Aug 2011, 18:09 -
alltoavi conversion problem after mkvmerge gui
By mazakou in forum Video ConversionReplies: 2Last Post: 1st Mar 2011, 16:30 -
mkvmerge GUI 4.4.0 Vs mkvmerge GUI 2.0.2
By Manospetrucci in forum Video ConversionReplies: 2Last Post: 6th Jan 2011, 20:34 -
Trouble with mkvmerge gui
By nzdreamer55 in forum EditingReplies: 0Last Post: 25th Nov 2010, 13:07
