hi all
am having a 42 inch lg plasma tv (divx supported)
Model Number:PDP42G10001
i want to know what is the best quality and size and conversion program to convert to.
thanks in advance
Convert what? DVD? Blu-ray? DV? Playback via what? DVD player? SD media player? HD Media player? Blu-ray Player?
thx for ur answer and what if i will play it using the usb port in the tv
You'll have to consult your manual or the manufacturer. Some LG models only play MP3 and JPG files via USB. Others can play SD and HD Divx.
RMVB File Question
By THUGGY1111 in forum Video ConversionReplies: 3Last Post: 17th May 2011, 20:33 -
No sound upon conversion from RMVB to DVD using WinAVI Video Converter
By kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 16:28 -
question about vhs to dvd conversion file type
By lotrmorgoth in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2009, 10:33 -
burn RMVB file to DVD to play on standard DVD player
By samoyed in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2009, 21:29 -
Whick dvd player with usb port can play rmvb file?
By haitang in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2007, 00:31
