  1. Hi, I don't understand this spesification means in my bluray player. When we using digital out (coaxial or fiberoptic), don't we send out raw digital data to external receiver ?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    DTS is a digital stream to the receiver. You can specify a 5.1 mix or a stereo 2.0 mix in the Blu-Ray setup menu.
    The selected stream is decoded in the receiver.
    http://www.kiva.org/about
  3. Besides, Although the player doesn't support DTS HD MA, I can play movie files with only DTS HD MA audio format. How I don't know??
  4. Originally Posted by winter snake View Post
    It down mixes it inside the player. The same way a dvd with only Dolby Digital will output stereo.
  5. Banned
    Freedonia
    All BluRay players must support DTS HD MA. It's a requirement like AC3 support on DVD players.
  6. Originally Posted by jman98 View Post
    My bluray player doesn't, you can look from its spec. philips bdp 2500. It only supports DTS and DTS 2.0 Digital Out that's why I asked this question
