Hi,
My Problem:
Having read 'Baldrick's' post on using MPC to adjust audio delay issues, I thought I'd try it. His thread is here:
https://forum.videohelp.com/threads/311331-How-to-fix-audio-out-of-sync-in-a-DVD-withou...y-reconverting
Trouble is on some files the playback picture is very dark. These same files play fine on PowerDVD 5. I would like to get it to work properly, but well enough to use it for audio adjustments would be okay. At the moment, it's even too dark for that - playback is very red. I am running it on XP SP3. Monitor settings seem okay for all other projects.
Power DVD seems quite tolerant of most files. If it helps, I've have the same problem with dark playback with the on board WMP.
I found this on the net: how to brighten playback on MPC:
http://www.brighthub.com/computing/windows-platform/articles/17248.aspx?image=4886
but I can't find the brightness adjustment under 'Options - Misc' in v. 6.4.9.1. Where has it gone?
My Solution:
Open MPC
Under View - Options,
Select 'Internal Filters' on right side is 'Transform Filters'
I selected (put a tick next) to AC3 and MPEG2.
You can also select source filters to play various types of file you want to play.
Results 1 to 1 of 1
Solved: How to play AAC file with Media Player Classic
By jimdagys in forum AudioReplies: 9Last Post: 4th Mar 2012, 17:06 -
SOLVED: Media Player Classic and codecs for Easy Subtitles Synchroniser
By bahjan in forum Software PlayingReplies: 0Last Post: 2nd Feb 2012, 13:43 -
No MP4 Audio Playback with Media Player Classic
By elling in forum Video Streaming DownloadingReplies: 1Last Post: 25th Jul 2011, 13:15 -
Media Player Classic audio playback problem
By qpskfec in forum Software PlayingReplies: 2Last Post: 3rd Dec 2008, 15:09 -
Solved: Can't Play WMV in IE with Media Player Classic.
By DarrellS in forum Software PlayingReplies: 0Last Post: 13th May 2008, 12:31
