I used the xstream option in Ripbot on a movie which is a bit big than my usual rips. I thought it was because of the lower CRF but it didn't make a difference when I increased it. Anyway, just curious what the difference is in size when I use xstream vs the other options
Results 1 to 18 of 18
http://www.kiva.org/about -
General
Complete name : E:\road.mkv
Format : Matroska
File size : 20.6 GiB
Duration : 1h 57mn
Overall bit rate : 25.1 Mbps
Movie name : road
Encoded date : UTC 2010-11-16 22:41:35
Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=4, N=48
Muxing mode : Container profile=Unknown@4.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 57mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 104 r1683 62997d6
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=14.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 1h 57mn
Bit rate mode : Variable
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Menu
00:00:00.000 : en:00:00:00.000
00:06:21.006 : en:00:06:21.006
00:10:25.458 : en:00:10:25.458
00:14:42.799 : en:00:14:42.799
00:19:47.186 : en:00:19:47.186
00:26:46.772 : en:00:26:46.772
00:30:23.155 : en:00:30:23.155
00:35:02.267 : en:00:35:02.267
00:41:08.800 : en:00:41:08.800
00:46:23.864 : en:00:46:23.864
00:50:48.587 : en:00:50:48.587
00:55:58.105 : en:00:55:58.105
00:58:57.909 : en:00:58:57.909
01:03:32.017 : en:01:03:32.017
01:11:33.873 : en:01:11:33.873
01:13:08.134 : en:01:13:08.134
01:15:55.551 : en:01:15:55.551
01:18:36.587 : en:01:18:36.587
01:24:45.998 : en:01:24:45.998
01:32:22.078 : en:01:32:22.078
01:35:55.959 : en:01:35:55.959
01:41:33.879 : en:01:41:33.879
01:43:32.081 : en:01:43:32.081
01:50:37.089 : en:01:50:37.089 -
Hmm, not clear from that info
"Overall bit rate : 25.1 Mbps"
FLAC audio "losslessly" compresses 50-60%. 6x 16 bit, 48 KHz channels uncompressed would be ~4.6 Mbps so FLAC should take that down ~ 50% to ~2.3 Mbps.Recommends: Kiva.org - Loans that change lives.
MKVExtractGUI -- doesn't tell you how big it is, but you can just extract the audio as a separate file easily and check it out.
The command line version of mediainfo (for Linux) does:
MediaInfo Command line,Code:Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Duration : 24s 928ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Video delay : -80ms Stream size : 779 KiB (2%)
MediaInfoLib - v0.7.34
EDIT: Mediainfo 0.7.36 for Windows also shows the audio stream size. AndyD, what version have you got?Last edited by intracube; 17th Nov 2010 at 05:50.
Thanks guys. I ended up extracting the video file using mkvextract since I couldn't extract the FLAC audio (not supported it seems). I found this to be really strange...
The video file is 19gb while the audio was a little over 1gb - does that make sense? For FLAC? I guess I was expecting a larger file. -
Ok thanks. I'll check out a later version. Now just wondering about the results from extracting.
Is 1gb for audio expected for FLAC? -
Not for 3 minutes. Maybe for an hour or two.
Also depends on how many channels.
Any valid FLAC files from a particular audio will be close to the same size, regardless of settings.
Generally, about 30-50% less than the equivalent WAVE file.
FLAC is lossless, and the difference between the highest and lowest compression settings is a few percent, at the cost of longer analysing time to create it.
The FLAC frontend (GUI) includes a "test" function.
See http://flac.sourceforge.net/faq.html -
It's a 2 hour video - 1gb FLAC is ok then? I don't know...I guess I was expecting something larger than that
Anyone? I'm holding off on backing up any more of my blurays till I know this. Will use FLAC if there really isn't going to be any real difference in size. I would have expected the audio to be around 4-5gb
Only 5 channels are sampled at 48kHz, the '.1' LFE would have a negligible effect on bit-rate. So that would make it ~1.9Mbps.
I would guess around 1.7GB for 2 hours.
'gb' isn't a valid unit of file-size. GB = gigabyte, Gb = gigabit. 1GB is the same as 8Gb.I would have expected the audio to be around 4-5gb
Both GB and Gb are used regularly, although Gb/Mb/kb is often used for streaming data and GB/MB/kB for static files.Last edited by intracube; 22nd Nov 2010 at 01:15.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
Joining a 3 part MKV
By yearofthespider2k3 in forum Newbie / General discussionsReplies: 8Last Post: 12th Jan 2011, 19:32 -
Cut a part from a MKV file
By H2SO4JB in forum Video ConversionReplies: 0Last Post: 17th Oct 2010, 10:15 -
mkv file too big for avchd
By mysts in forum Authoring (Blu-ray)Replies: 5Last Post: 3rd Nov 2009, 22:07 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36
