After encoding my movie in the film machine, I receive the following error message when it reaches the multiplexing stage.
Mplex is multiplexing the video and audio stream of file 1 .....
INFO: [Mplex.exe] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
INFO: [Mplex.exe] File F:\KNIGHT~1\TFM_EN~1.M2V looks like an MPEG Video stream.
INFO: [Mplex.exe] File F:\KNIGHT~1\TFM_EN~1.DTS looks like a dts Audio stream.
INFO: [Mplex.exe] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [Mplex.exe] Found 1 audio streams and 1 video streams
INFO: [Mplex.exe] Selecting dvdauthor DVD output profile
INFO: [Mplex.exe] Multiplexing video program stream!
INFO: [Mplex.exe] Scanning for header info: Video stream e0 (F:\KNIGHT~1\TFM_EN~1.M2V)
INFO: [Mplex.exe] VIDEO STREAM: e0
INFO: [Mplex.exe] Frame width : 720
INFO: [Mplex.exe] Frame height : 480
INFO: [Mplex.exe] Aspect ratio : 16:9 display
INFO: [Mplex.exe] Picture rate : 29.970 frames/sec
INFO: [Mplex.exe] Bit rate : 8552000 bits/sec
INFO: [Mplex.exe] Vbv buffer size : 229376 bytes
INFO: [Mplex.exe] CSPF : 0
INFO: [Mplex.exe] Scanning for header info: dts Audio stream 00 (F:\KNIGHT~1\TFM_EN~1.DTS)
INFO: [Mplex.exe] dts frame size = 2012
INFO: [Mplex.exe] dts AUDIO STREAM:
INFO: [Mplex.exe] Bit rate : 196608 bytes/sec (1536 kbit/sec)
INFO: [Mplex.exe] Frequency : 48000 Hz
INFO: [Mplex.exe] SYSTEMS/PROGRAM stream:
INFO: [Mplex.exe] rough-guess multiplexed stream data rate : 10333648
INFO: [Mplex.exe] target data-rate specified : 10080000
++ WARN: [Mplex.exe] Target data rate lower than computed requirement!
++ WARN: [Mplex.exe] N.b. a 20% or so discrepancy in variable bit-rate
++ WARN: [Mplex.exe] streams is common and harmless provided no time-outs will occur
Multiplexing finished.
DVDAuthor is writing the VOB files.....
Writing VOB files finished.
Finished authoring DVD
Is this an issue with the software? I'm using version 1.61. Or is it because of the audio? I tried using DVD Lab pro to author it and the video came out but there was no sound.
Any help is greatly appreciated.
the max total bitrate is too high. audio plus video must be under 10mbps, some specs say 9.8mbps. and it's vbr video so there could be peaks over 12mbps. i'd redo the video to cbr 8mbps and try again.
[edit] almost forgot. dts is not allowed as the only audio stream. a dvd must have an ac-3 or pcm track.--
I've reduced the bitrate and will encode it again and see if that fixes the problem. Thanks.
I get the same error when setting a lower bitrate. Any other ideas on how to solve this problem?
did you try ac-3 for the audio? dts alone is not allowed per the dvd spec, and it requires a dts tuner to decode. 1536kbps is not usually used on dvd either, it's mostly 768kbps.
The Film Machine Problem... MULTIPLEXING FREEZE
By supermannnnn in forum Video ConversionReplies: 3Last Post: 16th Dec 2012, 11:51 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 16:14 -
Adding menu to DVDI created with The Film Machine?
By naoise in forum Authoring (DVD)Replies: 0Last Post: 10th Dec 2009, 02:08 -
The Independent Film Channel - efficient film challenge - cash prizes
By minidv2dvd in forum Latest Video NewsReplies: 1Last Post: 23rd Oct 2009, 09:44 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 15:50
