im sure this has been covered just can't find the thread. question is if i have a bluray movie saved on my computer will i need some special codec to view the movie or special bluray media player im sure i'll need some codecs but will i have issues in any other departments(4example special monitor, bigger processor or more ram ect)? i usually watch movies with media player classic home cinema
You can try http://www.cyberlink.com/prog/bd-support/diagnosis.do and see if your computer is fast enough.
And if you want menu playback you must use tmt3 or powerdvd, you might have to use dvdfab virtualdrive to mount the blu-ray as blu-ray drive.
And this is not an authoring issue. Moving you our playback section.
Will my computer specs support Blu-ray at all?
By takearushfan in forum DVD & Blu-ray WritersReplies: 19Last Post: 15th Mar 2012, 18:21 -
Playing blu ray on my computer from a player
By Dankriss in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2010, 11:56 -
Playing Blu-ray on my computer
By nickelzy in forum Blu-ray RippingReplies: 10Last Post: 14th Mar 2009, 11:06 -
problem viewing blu ray movies on pc
By sdavis in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Sep 2008, 08:47 -
Blu-Ray burner not working in new computer
By Megahurts in forum ComputerReplies: 4Last Post: 1st May 2008, 01:21
