Is using VirtualDub 64bit significantly faster than 32 bit ?
For me it was a little different. My SATA drives were able to sustain read/writes about +40%. Reads went from 50-60MB/s to 90-100Mbs(*). Writes from 30-40 to 50-60MB/s. For file transfer between drives, it made a noticeable difference.
So anything that was i/o bound saw significant difference, CPU probably saw an extra 5%. Doing something like a NullTransform (a simple crop) was much faster. Once you start adding filters and things become more CPU intensive, the less advantage you'll see.
For memory intensive operations, you should also see a significant difference. If compiled correctly and able to take advantage of 64-bit memory operations, applications should be should be faster as well(+).
In general, 64-bit computing is very new to Windows compared to Unix variations that have been around 20+years. You just have to find the ones that take advantage of it. I'd also be willing to bet, just a gut feeling, that most applications would rather try to take advantage of multiple cores/CPUs for a bigger bang for the buck.
* = Initial read/writes before the buffers filled were more than 100%. But that only lasts a few seconds or so. For instance my reads start at 120-130MB/s then slide to a sustained 90-100.
+ = That's a big if. Many programs kept their 32-bit logic but compiled with a 64-compiler.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 13:55 -
Lame MP3 on Virtualdub 64bit (win7 64bit)
By EdoScario90 in forum AudioReplies: 5Last Post: 2nd Sep 2012, 11:30 -
New Ripbot264 64bit
By jah711 in forum Blu-ray RippingReplies: 2Last Post: 8th Nov 2009, 10:17 -
XP Pro 32bit Vs. 64bit ?
By Noahtuck in forum ComputerReplies: 72Last Post: 5th Aug 2009, 13:37 -
Xvid for 64bit XP
By SerbianBoss in forum Video ConversionReplies: 1Last Post: 12th Jan 2008, 07:09
