Ok I've been playing around with this and trying to get the best results but haven't found anything to my liking.
What I am trying to do is burn a UFC dvd to .avi and then seperate each of the fights into a seperate file so I can stream any fight on my Xbox.
Currently I have been burning with dvdfab to computer and then using Any Video Converter to convert the VOB files to a .avi. Then I open that .avi in Any Video Converter and make the cuts in the video but it has to do the conversion again then I have all the files seperated.
The quality of the video is not the best probably because it is avi?? Also is there a better program I can use to make the cuts so it wont have to convert the output?
Any help would be greatly appreciated
Use VirtualDub in Video -> Direct Stream Copy mode (mark-in only on keyframes). Or Smart Rendering mode (only cut GOPs recompressed).
It looks to me like he's looking for a better way to do it, one not involving converting to AVI first. If so, you can cut the DVD into pieces using DVDShrink and reauthor into several smaller DVDs, one for each fight. No recompression; no quality loss. Or just cut the VOBs without reauthoring using MPEG2Cut(2) (if the XBox can play VOBs). Or convert the VOBs to MPG using VOB2MPEG if the XBox plays MPGs. Again, no quality loss.
problem with conversion from DV-AVI to DVD
By obadvw in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 17:08 -
Downloaded AVI to DVD problem
By karlh10 in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 14:55 -
Avi to DVD problem
By slipknotkod in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 01:57 -
AVI to DVD looking squished problem
By mashimiriam in forum Newbie / General discussionsReplies: 8Last Post: 31st Mar 2008, 19:17 -
dvd to avi problem
By hobmob in forum DVD RippingReplies: 7Last Post: 2nd Sep 2007, 17:40
