Results 31 to 33 of 33
Yadif requires a special command line:
Load_Stdcall_plugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll")
If you want, you can create an AVSI script with that command in your plugins folder (AVSI scripts are exectuted automatically any time AviSynth is invoked). Then Yadif will automatically be available any time you open a script.
Just FYI: I demuxed the MP4 file with Yamb, then remuxed the elementary streams with the video frame rate flagged as 30i instead of 60i. The resulting file was much more compatible with many programs.Last edited by jagabo; 17th Nov 2010 at 10:41.
It worked !! you guys ROCK !! Thanks for the help - I'll make sure I stick to 1280x720 60p from now on
Can't Jump After Burning DVD
By analytalica in forum Newbie / General discussionsReplies: 11Last Post: 17th Mar 2013, 08:30 -
Weave deinterlace plugin for Progressive Segmented-Frame videos(After Effec
By Stears555 in forum Video ConversionReplies: 1Last Post: 8th Feb 2012, 15:20 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Slo-mo & frame blend, deinterlace, flicker, export settings, lions, tigers
By ivanarias in forum EditingReplies: 3Last Post: 24th Feb 2010, 22:35 -
Jump right to movie
By raschko in forum Authoring (DVD)Replies: 0Last Post: 28th Oct 2007, 15:48
