Results 1 to 17 of 17
    Jun 2007
    Kuwait
    Hi,
    I'm doing some video editing add the video with multi audio tracks ( Jap, Ita & Ara ) and i want to export this video with multi audio not to mix this audio. How i can do that ?!
    Best Regards,
    SB4
  2. you can export the audio separately, then multiplex it with another tool . Which tool you use will depend on what export format you choose
    Jun 2007
    Kuwait
    How to export the audio separately ?!
  4. you could disable the other tracks, and export the audio, or put the audio track in a separate sequence
    there might be other ways (I usually don't deal with multiple audio tracks)
    Jun 2007
    Kuwait
    Ok, Which tool can help me to add multi audio to the video file and convert this file to MKV ?!
  6. If you have the tracks exported, use mkvtoolnix
    Jun 2007
    Kuwait
    thanks poisondeathray
    Jun 2007
    Kuwait
    I have another problem when i export the video from premier pro cs5 the video quality is not the same as the original video, what should i do ?!
  9. What settings for export ?
    You can't keep the same quality, you are re-encoding
    Unless you use a lossless format = big filesize (e.g. uncompressed , lagarith, huffyuv)
    If you increase the bitrate you can minimize quality loss , or if you use a better encoder
    Jun 2007
    Kuwait
    I'm using both Match Sequence settings option and H.264 (Apple TV 480P with default settings) but the result is the same not good quality...!
    In the previous version Premier Pro CS3 i can use Windows Media Video 9 codec but with the new version Premier Pro CS5 i can't or i don't know how to use it...?!
    Video file info:
    General
    Complete name                    : tetsujin_01.avi
    Format                           : AVI
    Format/Info                      : Audio Video Interleave
    File size                        : 294 MiB
    Duration                         : 23mn 14s
    Overall bit rate                 : 1 772 Kbps
    Writing application              : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library                  : VirtualDubMod build 2540/release
    Video
    Format                           : VC-1
    Codec ID                         : WMV3
    Codec ID/Info                    : Windows Media Video 9
    Codec ID/Hint                    : WMV3
    Duration                         : 23mn 14s
    Bit rate                         : 1 502 Kbps
    Width                            : 640 pixels
    Height                           : 480 pixels
    Display aspect ratio             : 4:3
    Frame rate                       : 25.000 fps
    Bit depth                        : 8 bits
    Bits/(Pixel*Frame)               : 0.196
    Stream size                      : 250 MiB (85%)
    My sequence settings:
    EditingMode: Desktop
    Timebase: 25 frames/second
    Frame Size: 640x480
    Pixel Aspect Ratio: Square Pixels(1.0)
    Fields: No Fields(Progressive Scan)
    Display Format: 25fps Timecode
  11. The matching sequence settings are fine, but the EXPORT settings are what matter - use a higher bitrate. Sequence settings are separate from export settings.
    You will find h.264 will give higher quality than wmv at the same bitrate
    Jun 2007
    Kuwait
    Is it possible to tell me the best export settings for this file. please ?!
    I'm really tired of the large number of useless attempt ...!!
  13. There is no "best".
    If using adobe, I would use h.264 to export
    Personally I would export uncompressed and use a different encoder, x264 or a gui for it like megui, handbrake, ripbot, etc...
    Jun 2007
    Kuwait
    Ok, can i use VirtualDub to add some filters to the video and save it as avi file ?!
  15. Originally Posted by SB4 View Post
    You can if you want to . Nobody is stopping you
    But if you export out of premiere before using vdub, use no compression, or lossless compression , otherwise you will lose more quality
    Jun 2007
    Kuwait
    Ok, I'm using Uncompressed Microsoft AVI and i will see the result...
    Jun 2007
    Kuwait
    I will return to the previous version adobe premier cs3
