Results 1 to 9 of 9
    Aug 2010
    Brazil - São Paulo
    I use the mpeg2 encoder QuEnc to convert my avi files to mpeg2, but some files during the conversion has some "overflow", I wondered why this happens?
    MediaInfo of this file:
    Format : AVI
    File size : 644 MiB
    Duration : 1h 21mn
    Overall bit rate : 1 107 Kbps
    Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library : VirtualDubMod build 2540/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 21mn
    Bit rate : 1 102 Kbps
    Width : 688 pixels
    Height : 368 pixels
    Display aspect ratio : 1.870
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.182
    Stream size : 641 MiB (100%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    My Quenc Command Line:
    -i "C:\filmes\avisynth_script.avs" -o "C:\filmes\Encoded_video.m2v" -b 7533 -maxbitrate 9000 -mpeg2mux svcd -maxbframes 2 -vbr -dc 10 -gopsize 18 -priority 5 -hq -notrell -2 -aspectratio 4:3 -auto -close
    I was wondering what causes overflows, could someone tell me?
    maybe it could be because of the "muxing mode" or bitrate, but i'm not sure.
    Edit: I forgot to say, just happens to pass 2.
    thx
    USA
    Buffer overflows probably. They are when the program tries to use more memory than the buffer is set up for and writes to another memory location. Usually causes a crash. This article from Wikipedia may explain it a bit better: http://en.wikipedia.org/wiki/Buffer_overflow
    Aug 2010
    Brazil - São Paulo
    but it just happens to some videos, i don't understand it.
  4. Banned
    Freedonia
    Why are you using the svcd profile argument on mpeg2mux? What you are creating is not valid for SVCD.
    Aug 2010
    Brazil - São Paulo
    What value should I put?
  6. I guess Quenc with your setting -maxbitrate 9000 surges the bit-rate spontaneous spikes higher than 9800 kbps which may lead to buffer-over flow. Try to lower -maxbitrate setting little-bit to 8800 or 8600 and see if it is still over-flows. Buffer overflow may also leads to memory leaks causes undesired output.
    Aug 2010
    Brazil - São Paulo
    thx, I tried but still having "overflows" ;/
  8. Banned
    Freedonia
    DVD.
    Look at our link "What is VCD" to see a table that tells what SVCD contains. What you are creating is not even close to being SVCD.
    Aug 2010
    Brazil - São Paulo
    If I authoring a DVD with this file with overflows, I'll have problems to watch on my DVD?
