  1. I'm looking for help, I tried several things and can't get any converter to do this job. My last attempt was with TOTAL VIDEO software and here are my steps:
    On my iMac (10.6.5), I am able to make a straight copy of the DVDs with Toast 8, but I can't convert to NTSC and built in DVD player won't play the DVD (I'm in the US, it says not supported). The DVD will play in VLC Player however. So, when I'm in TOTAL PLAYER, I get the following.
    When I open the DVD, I can only open the VIDEO_TS folder, it has the following files:
    VIDEO_TS.BUP - 12KB
    VIDEO_TS.IFO - 12 KB
    VIDEO_TS.VOB - 45 KB
    VTS_01_0.BUP - 41 KB
    VTS_01_0.IFO - 41 KB
    VTS_01_1.VOB - 1.07 GB
    VTS_01_2.VOB - 1.07 GB
    VTS_01_3.VOB - 1.07 GB
    VTS_01_4.VOB - 704.1 MB
    When I select the CD/DVD format in the top dropdown and select NTSC DVD and then click to convert, I get these messages one at a time, so when I uncheck the file, the next error comes up, here they are in the order
    /Volumes/Wedding-Part1/VIDEO_TS/VIDEO_TS.BUP: Unknown format
    /Volumes/Wedding-Part1/VIDEO_TS/VIDEO_TS.IFO: Unknown format
    /Volumes/Wedding-Part1/VIDEO_TS/VTS_01_0.BUP: Unknown format
    /Volumes/Wedding-Part1/VIDEO_TS/VTS_01_0.IFO: Unknown format
    Error while opening codec for output stream #0.1 - maybe incorrect parameters such as bit_rate, rate, width or height
    When I open VLC player and get info for the VOB files, they all are
    AUDIO Stream 1, codec mpga, 48000Hz, 224 kb/s
    VIDEO Stream 0, codec mpgv, 720x576, frame rate 25
    The only thing TOTAL VIDEO was able to convert is VIDEO_TS.VOB (but it has zero minutes of video?). When I go to settings and try to find the mpga or mpgv codecs, they're not listed.
    Can anyone on the forum help? I will pay for the software, just need something that will work. Holidays are coming and my wife is not happy that for the last 4 months I was unable to convert from PAL to NTSC. We live in the US, but the wedding was in another country and the wedding photographer made for us DVDs in the PAL format. I got a special DVD player that will play the PAL discs, but when we visit family we have to get these converted to NTSC DVD so they can watch, too.
    I also have a Video CD disc that has a nice summary of the wedding, but that won't play in the iMAc at all, not even in VLC player. Toast won't recognize it to make a copy either. I am getting desperate.
    We also have a Vista Laptop, but that would be my last resort.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    VIDEO_TS.BUP - 12KB
    These are DVD files. Every DVD has these.
    Tell your wife it is NOT easy....because it is NOT easy. Even seasoned pros HATE converting between video formats and avoid it at all costs.
  3. Member Backpain's Avatar
    Oct 2009
    You would need to hookup you PAL player to your MAC via a converter box, (me I have a video card in my PC witch captures from my TV or VCR and DVD player) and record the video onto it your MAC. Then remaster the video with software and burn it to a DVD.
    If it feels good, do it.
    Jul 2001
    It would probably be easier to get a divorse.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
    There is no magic "PAL to NTSC" software.
    Even then, most PAL/NTSC conversion methods are crap.
    Read this: http://www.digitalFAQ.com/guides/video/convert-pal-ntsc.htm
    Most all DVD players worldwide play both PAL and NTSC.
    It's easier to buy a new DVD player.
    Or get that divorce.
    Aug 2006
    A small or portable DVD player with a PAL to NTSC video converter that you could take with you when visiting family would be a whole lot cheaper than a divorce, and a whole lot less trouble than converting the video.
    Here is one example,
    http://www.bhphotovideo.com/c/product/674870-REG/Philips_PET_741_PET741_7_Multisystem_Portable.html
    ...and region-free versions of it are available elsewhere for more if you want that:
    http://www.220-electronics.com/portable/philips741.htm
    There should be others that would work too.
  7. So you have some PAL dvd's that were created by a wedding videographer that will not play on your relatives (in the USA?) dvd players. & your relatives want their own copy. If they do not want thier own copy take your vista laptop and output to their TV
    Surely a local service could do the transfers for you?
    questions, I am presuming you are travelling to your relatives by plane so carrying hardware is a pain?
    Do you have a dvd recorder, or have access to one? , if you do, play the dvd's on that and output the result to the dvd recorder, the resulting dvd's(make sure they are finalised) will then play on your relatives dvd player.
    solutions:-
    buy them a suitable dvd player for Christmas and just copy the wedding dvd's
    use a local service
    send them to me (preferably a copy) and I will convert for you for free, I do this coz I find this subject makes me want to scream and run round the world.
    if you have a dvd recorder do as previously suggested
    use tmpg enc to convert, it has always worked for me
    Ask the person who created the dvd's in the first place to create NTSC versions.
    If you need any more help feel free to pm me, this subject has been discussed many many times on this forum and is easy to fix
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
