I have a hybrid eSATA/USB3 connection on my laptop, and was wondering what can I do with that.
You can use an external eSATA hard drive, which is usually much faster than USB. I have USB3 on one of my PCs but haven't tried any USB3 devices so I have no idea how fast it would be. But eSATA hard drives run at the same speed as the internal drives in the PC, so they should be faster.
What brand and model is the laptop? I'm wondering what sort of connector it uses for eSATA/USB3. -
Toshiba Qosmio.
So should I buy a esata enclosure? What's the best way to go? I would like to use that connection with a HD to render video. I don't see any esata portable drives at Amazon. -
If you have the proper cable, just about any external eSATA HDD will work. They will need an external power source unless you use one of the small lower power 2.5 HDDs that can run off the PC. About 56 external drives from NewEgg for illustration. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007601+600003465&QksAut...pe=&srchInDesc=
Or you could get a enclosure and put about any SATA drive in there. These from Cooldrives: http://www.cooldrives.com/index.php/hddenclosures.html?cat=223&external_interface=318
If you really need one powered from the PC, these Western Digitals work well, but they are USB2.0, so not quite the same performance as eSATA. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007601+50001306+6000034...pe=&srchInDesc=
Not sure what you have available for suppliers in your location, but even Amazon should have similar external drives or enclosures. -
Thanks fer the info, I'm gonna go for a 2.5 enclosure and 2.5 500G Hitachi drive, about $85 OTD all together from Amazon. Like you said, it needs two cables when hooked to esata port, but I don't see any single cable units like the portable USB drives we all have, guess it's too new.
the 2.5 case needs 2 connections because it needs enough power from the 2 usb connections to get the esata speed...i have a coolmax 2.5 esata enclosure but dont use it. I have, in regular use, a rosewill esata enclosure with a 640gb drive. Normal transfer rate is around 66mbs a second...usb 2 is around 22mbs. USB 3 speed they say is a tad higher than esata but I'm bettin the difference is negligible
if u have a decent laptop, make sure you get into the BIOS and enable "AHCI", so u'll be able to hot swap the drive. -
Be careful turning on AHCI in BIOS with a OS already in place, you may get a blue screen on boot. If so, just disable it in BIOS again. Most times it takes a registry change with an installed OS. Not a difficult fix, you can look it up with a internet search. Not being able to hot swap a eSATA drive isn't a big deal, you just have to plug it in and do a restart.
Any Laptops with ESATA out there?
By jbitakis in forum ComputerReplies: 5Last Post: 10th Nov 2011, 12:20 -
eSATA hookup
By yogart in forum Newbie / General discussionsReplies: 12Last Post: 23rd Jan 2010, 17:58 -
eSATA strangeness
By piano632 in forum ComputerReplies: 5Last Post: 3rd Apr 2008, 10:09 -
how to connect esata port on MB to external esata HDD
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Dec 2007, 12:45 -
Firewire VS. eSATA/eSATA II - which would you rather have?
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th May 2007, 09:59
