I need to capture about a minute of flash video that is playing in a web browser. None of the youtube-like downloaders have worked. I tried Camstudio but the capture was lousy, choppy. Then I tried screencastomatic.com and while the video seemed to capture ok, I couldn't bring it into Sony Vegas! There's got to be a solution here?
you could probably download it with streamtransport , if not, then if you post the url someone might have better suggestions
downloading is usually preferable to capturing
if camstudio was choppy, it might be your computer specs aren't fast enough to capture in real time, you can try capturing in a lower quality , less cpu intensive codec like divx -
That stream program worked perfectly, wish I had come to the forum earlier!! - THANKS!
Looking for a good web video/flash player
By dpunkz in forum Video Streaming DownloadingReplies: 5Last Post: 21st May 2011, 11:54 -
Capturing Web Cam Through Adobe Flash In Browser
By johnsmith153 in forum Video Streaming DownloadingReplies: 0Last Post: 11th Jun 2010, 18:35 -
Boosting Low Audio in Web Browser Video
By badadjective in forum Software PlayingReplies: 1Last Post: 27th Jun 2009, 05:47 -
Help with web video... Flash maybe After Effects???
By pengh in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2008, 10:27 -
Converting video to in-browser playable flash
By MarquisdeOz in forum Video ConversionReplies: 1Last Post: 28th Sep 2007, 08:05
