I have a Thomson Scenic DTH8550 which will not record onto the hard drive. I used to be able to store 30 hours or so but at the moment the video library is down to 4 recordings totalling about 4 hours. I have tried putting the machine into standby and back on again which used to recall space but that is no longer happening. I have also reset back to factory settings as described inthe manual but again this has had no effect. I get a message saying "THERE IS NO SPACE LEFT" when I try to record.
Any one got any ideas?
Results 1 to 1 of 1
Noon: How do I tell WMC to record to another HDD after primary is full?
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 17th Apr 2011, 13:22 -
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 14:09 -
DVR machines that can record directly to an external HDD?
By ryanwayne in forum Capturing and VCRReplies: 0Last Post: 16th Sep 2009, 23:25 -
HDD camcorder - can you record to same file (ie: pause) when stop/starting?
By z0diac in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 24th Jun 2008, 23:51 -
how to record from the HDD to a DVD+RW disk, using a Yamada DVR-9300HX
By The Muddler in forum DVD & Blu-ray PlayersReplies: 7Last Post: 1st Aug 2007, 14:00
