Hi,
I have a KWorld DVD Maker USB 2.0 with USB connected to the PC, and the other end has a female svideo and red, white and yellow RCA cables in order to connect to either a camcorder or VCR. My VCR only has the coax connection and 1 SCART so I have connected them to a scart adapter with input for red white and yellow RCA on one side and the other into SCART socket on the back of the VCR. I am trying to convert my old VHS tapes to DVD using this device but with everything connected and the Software installed - Cyberlink PowerProducer and PowerDirector or Windows Movie Maker it displays a black screen (no picture) when I choose options for capture video. I have checked all the cables are working and have tried on two seperate pc's to no avail. I also even tried a similar device called Easy Cap to no avail. Am I missing something here or should it work? I have tried with a camcorder by connecting the RCA to the KWorld DVD Maker and I can successfully edit the video from that but when I connect the VCR I get nothing. Any help would be appreciated!
Ok, you have verified the card's input by using a second device to test. Good. This should have been done first before moving the card to another PC.
Follow the same strategy with the other end of the equation. Connect the VCR yellow cable output to a TV or camcorder and verify it is working. You may need to change a menu setting on the VCR to enable that output. -
Thank you for the quick replies. I will try looking for a menu on the VCR and also connect the yellow RCA cable as mentioned. I wondered if I need a new VCR with RCA output and inputs instead of a scart connection?
Found a menu on the VCR and changed around all the settings to no avail. I tested the yellow RCA cable to a camcorder and it works fine but nothing when connected with VCR. Do I need a new VCR with RCA outputs?
Hi,
Thank you for your help. I got it working! I needed a SCART adapter with RCA outputs and an IN OUT switch set to OUT. Now the VCR displays on the PC ready for editing! -
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 04:36 -
S-Video vs Composite for capture from S-VHS VCR
By HDClown in forum Capturing and VCRReplies: 5Last Post: 23rd Mar 2010, 08:23 -
Guide needed for Video Capture and Encoding
By jsmithson in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2009, 06:05 -
capture video from VCR
By nbdeb59 in forum Capturing and VCRReplies: 2Last Post: 3rd Jul 2009, 00:57 -
Plextor M402U - Capture Device not recognised (WINDVD and Nero)
By phantomwalker in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2008, 21:52
