Hi,
I am attempting to convert a m2ts file into a mkv using ffmpeg. I run ffmpeg with the following options.
However I get the following when running.Code:ffmpeg -i 00002.m2ts \ -vcodec libx264 \ -vpre slower \ -s hd1080 \ -aspect 16:9 \ -acodec ac3 \ -f matroska \ -map 0:0 \ -map 0:1 \ ~/test1.mkv
I don't understand what I have done wrong with mapping the streams I want from the source to the output. Thanks in advance for any help.Code:FFmpeg version SVN-r25719, Copyright (c) 2000-2010 the FFmpeg developers built on Nov 11 2010 14:04:42 with gcc 4.4.5 configuration: --enable-gpl --enable-libx264 --enable-encoder=x264 libavutil 50.33. 0 / 50.33. 0 libavcore 0.12. 1 / 0.12. 1 libavcodec 52.94. 4 / 52.94. 4 libavformat 52.84. 0 / 52.84. 0 libavdevice 52. 2. 2 / 52. 2. 2 libavfilter 1.60. 0 / 1.60. 0 libswscale 0.12. 0 / 0.12. 0 [NULL @ 0x1aa6d50] start time is not set in av_estimate_timings_from_pts [NULL @ 0x1aa8c60] start time is not set in av_estimate_timings_from_pts [NULL @ 0x1aaab70] start time is not set in av_estimate_timings_from_pts [NULL @ 0x1aaca80] start time is not set in av_estimate_timings_from_pts Input #0, mpegts, from '00002.m2ts': Duration: 02:41:41.69, start: 1.991000, bitrate: 37022 kb/s Program 1 Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc Stream #0.1[0x1100]: Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s Stream #0.2[0x1101]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s Stream #0.3[0x1102]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s Stream #0.4[0x1103]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s Stream #0.5[0x1104]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s Stream #0.6[0x1105]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s Stream #0.7[0x1200]: Subtitle: pgssub Stream #0.8[0x1201]: Subtitle: pgssub Stream #0.9[0x1202]: Subtitle: pgssub Stream #0.10[0x1203]: Subtitle: pgssub Number of stream maps must match number of output stream
If you try another audio stream do you get same error?
In plasma TV "Number of pixels" and "Number of dots" it's not a same term?
By flash_os in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2011, 12:27 -
Question about number of listeners to a particular audio stream
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 20:57 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 08:16 -
Using ffmpeg to mux an arbitrary number of streams from multiple files
By punmaster in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 00:14 -
Using ProGold to number slides and show this in the output
By cubmar in forum EditingReplies: 2Last Post: 21st Dec 2007, 02:36
