For close to 3 weeks XVID4PSp 5.0 everyday version has been great for me but now encodes that are around 8 hours are freezing my comp. 4 hour ones are still fine. I've uninstalled and re-installed but so far no luck. I was wondering if the 6.0 version would be better? I just like the one I have now and use to it. Thanks for any help.
My first guess would be that your computer is overheating on longer encodes. This could be down to dust, a broken fan, or other aging parts. Simple test - pull the side off the case and use a small desk fan to blow cool air through the unit while you encode (just aim the fan across the open the case, not directly into it). If you encodes don't lock up the system, heat is your culprit.
Read my blog here.
Xvid4psp help
By skorpinok in forum EditingReplies: 2Last Post: 26th Jun 2011, 22:28 -
Help with Xvid4Psp
By xNesX in forum Video ConversionReplies: 3Last Post: 19th May 2011, 09:22 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 06:39 -
XviD4PSP HELP!
By jbird69 in forum Video ConversionReplies: 1Last Post: 13th May 2010, 23:45 -
XviD4PSP
By gjordan12198 in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 02:52
