Hi! I'm new in this forum.
I have lots of Video Clips (VOB Format), which I'll convert to MKV (there's no problem), but VOBs have black fields :
Is there any program which I can eliminate dark fields :
and get video like this :
Sorry for big pics![]()
Only way to crop the VOB file is to indeed re-encode, which you're already doing and, as Baldrick said, you'll be fine with those apps.
Keep in mind, you may have to also take care to resize after cropping to avoid distortion, depending.
If I'm assuming correct, those samples look like they're 16:9 content letterboxed in a full-frame 4:3 - you would need to cut 72 pixels off the top and bottom (assuming you're in PAL land or 60 in NTSC) and resize to 720x576/480. If using non-square pixels you will need an aspect ratio of 16:9 in your encode to change to pixel aspect ratio to avoid distortion.
If using AviSynth, such as with StaxRip or other, it's easy:
To crop 72 pixels off the top and bottom:
To resize to 720x576:Code:crop(0, 72, 0, -72)
Code:LanczosResize(720, 576)
I hate VHS. I always did. -
Thank You for fast answers
I am using StaxRip
With Cutting\Resizing I want to get image 720x406 - 16:9
What parameters I have to put?
sides cut off on widescreen format
By rayzor02 in forum DVD RippingReplies: 14Last Post: 5th Aug 2011, 14:51 -
Adobe Premiere Elements 7 - widescreen dvd cut off on the sides
By bigmic789 in forum Video ConversionReplies: 9Last Post: 5th Aug 2011, 08:44 -
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 09:54 -
Sides of picture cut off on TV after AVI to DVD
By HavoK041 in forum Newbie / General discussionsReplies: 1Last Post: 8th Aug 2007, 04:41 -
Video cut on sides of TV of Burned DVD
By theguy1991 in forum Authoring (DVD)Replies: 6Last Post: 29th Jun 2007, 19:24
