i have a folder that has a DivX movie and the subtitle. my question is. Is there a program that would allow me to convert the to whatever but with the subtitle included. i have tried convertextodvd, but it doesn't work or i just don't know how to do it. I would love to end up with a DivX with the subtitle already included. thanks.
You want to burn the subs into the video? If so, you can use AutoGK for the job. Baldrick has a short guide:
https://forum.videohelp.com/threads/256625-How-to-add-permanent-subtitles-with-AutoGK-a...I-DivX-or-XviD
That's for creating another DivX AVI. It won't create a DVD for you as (apparently) you tried to do with ConvertXToDVD. If that's what you want, to convert the AVI to DVD with selectable subtitles, then maybe try AVS2DVD. -
You might also try AVIAddXSubs, too, depending on the type of subtitles you want and have.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
