Hi to every body ,its great to be here ...
How to cut particular parts from an MKV format file with out quality loss (the file is large like 8gb) ?
pls somebody help in this .... ( iam using win7 32 bit )
bro , i tried my renaming the file to mp4 but while choosing that file it says "Editing of elementary streams is not yet supported" error .........
wot to do ? -
I take it that VideoReDo does not like your MKV. You could try AviDemux to remux it as a true MP4. From the command line this is done with avidemux2_cli.exe --load "%~n1.mkv" --output-format MP4 --save "%~n1.mp4"
You have to answer a couple of prompts for the remux to run, the one about H.264 (assuming it's AVC/H.264) and another one about AC3 not being valid for MP4 (again assuming AC3 audio). -
MKVMerge:
Load MKV -> Global tab -> In the splitting menu, select "Enable splitting" and in "...after this duration:" choose where you wish to cut. If it's just one cut (at a time) enter 2 in "max.number of files:" to avoid dozens of files depending on where you cut.
You can select in time, or seconds where exactly you wish to cut, but it won't be frame accurate.
I can't wait for VideoReDo's H.264 editor to fully mature for frame accuracy - it's due time. If you need an MP4 for this, just use MKVExtract, or TSMuxer to pull the streams from the MKV, and use MP4 Muxer (An MP4Creator GUI) to create a true MP4 file out of them.
All free tools till VideoReDo's H.264 hits primetime. (Should be worth buying then.)Last edited by PuzZLeR; 12th Nov 2010 at 12:34.
I hate VHS. I always did.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
MKV Cutter with preview window for H264 in MKV format?
By texas1 in forum Video ConversionReplies: 1Last Post: 9th May 2010, 06:25 -
MKV Cutter ??
By RVD2720 in forum Video ConversionReplies: 2Last Post: 13th Mar 2009, 18:45 -
DVD Cutter
By akakiami in forum EditingReplies: 6Last Post: 23rd Oct 2008, 07:04
