I'm really frustrated with MKV files - I can get high quality videos that are of this format
BUT: I want to play on my Blu Ray player that ONLY will play avi files like Xdiv and DivX
Yes, I can go out and buy an MKV player - but these look horrible and I would much rather have a Blu Ray player that played MKV!
Changing from MKV to avi - you lose quality right?
Is there any way of converting and not losing quality?
OM
You can remux from MKV to AVI. But unless the codecs are acceptable to your AVI playing Blu-ray player (ie, Divx/Xvid) it won't play them. You will lose some quality if you recompress them with Divx/Xvid. And if they are high def files you'll probably have to downscale to standard definition resolutions (not more than 720 pixels wide, 576 pixels tall) for you player (many Divx Blu-ray players will only play standard definition AVI files).
oh damn! back to square one then
i've got an avi in high definition resolution - i assumed if i burned to a dvd, i would be able to play - from what ur saying this won't be the case!
aaaah! -
Back to square one is needed.
MKV and AVI are wrappers, not codecs. So taking your original question at face value yes you could change the wrapper from MKV to AVI but there is little chance it would play in a Blu-Ray player. Blu-Ray players in general want MPeg2, h.264 or VC-1 in m2ts transport stream wrappers. Even then, these players want strict disc formatting in Blu-Ray or so called "AVCHD" file structures.
I'm unaware of a Blu-Ray player that accepts divx or xvid HD files.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
converting blu-ray to mkv without losing quality
By Arkadietz in forum Blu-ray RippingReplies: 5Last Post: 3rd Oct 2011, 18:31 -
How do you convert HD 720p MKV file to MP4 HD file without losing quality?
By SoccerLover in forum Video ConversionReplies: 18Last Post: 4th Nov 2010, 09:30 -
Convert AVI to MPEG-1 without losing quality: What tool?
By GeekyChocolate in forum Video ConversionReplies: 8Last Post: 28th Mar 2009, 17:42 -
convert mkv to avi with the same quality. How ?
By SB4 in forum Video ConversionReplies: 10Last Post: 30th Jan 2009, 07:26 -
How to convert AVI to MP4 using H.264 encoder without losing video quality
By VidHunter in forum MacReplies: 0Last Post: 21st Dec 2007, 02:04
