I have a lot of Bluray rips in mkv containers some of these have no subtitles and can not be found on severals subtitle sites therefor i want to rip my subtitles from my DVD and then put it into the mkv file
I can se thath all Bluray subtitles does match all bluray rips because they all are the same format, not like the dvd witch can be pal or ntsc
can any body please tell me hav i adjust my pal dvd subtitles to my bluray rips ?
hope my english is ok and you understand my question![]()
Best Regards
Flarup -
Subtitle Edit. No you wont find any dvd to blu-ray setting. But you can try the syncronisation->point sync.
Or try subtitle workshop, aegsub.
Adding/editing subtitles with .ts material (BluRay-rip)??
By Totaldental in forum SubtitleReplies: 4Last Post: 7th Sep 2014, 08:36 -
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15 -
playing dvd converted to mkv on bluray
By bkstaff in forum Video ConversionReplies: 2Last Post: 5th Jun 2011, 20:59 -
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 04:42 -
bluray rip mkv to mp4 for the xbox
By t-mac in forum Authoring (Blu-ray)Replies: 1Last Post: 24th Jun 2009, 22:58
