Thread: Laggy .MOV playback in Virtualdub
  1. #1
    Member
    Nov 2010
    AUS
    Posts
    5
    Hi All,
    I'm getting very laggy playback when trying to open a 720p 60fps .MOV in VirtualDub. The footage plays fine in Quicktime and in WMP.
    VirtualDub is at it's default settings, and I have installed the Quicktime plugin and set the Mode=2 in the Quicktime.ini (otherwise I just get a green screen in Virtualdub and playback results in Virtualdub crashing!).
    Any ideas on how to improve performace?
    I'm running Win7 64bit, on an Intel Core2Duo 6600 @ 3.2Ghz, 4GB RAM, Gigabyte 9800GTX 1GB.
    Cheers,
    a1ienz.
    I'm a MEGA Super Moderator Baldrick's Avatar
    Posts
    43,713
    Re: Laggy .MOV playback in Virtualdub
    Virtualdub is not a video player. Or do you get laggy playback after exported from virtualdub?
    Member
    Nov 2010
    AUS
    Posts
    5
    Well I get both... the playback is laggy but the output is laggy too.. audio is choppy and the video looks like it's in slow motion almost.
    Member
    Dec 2005
    Posts
    59,226
    What compression codecs did you use for the output file? And just to be clear -- you use File -> Save as AVI to create an AVI file with the above compression and that AVI file plays back jerky in a media player?
    Member
    Nov 2010
    AUS
    Posts
    5
    Quote Originally Posted by jagabo View Post
    yep file then save as avi. All settings are default so it's saving without any compression codecs.
    Member
    Dec 2005
    Posts
    59,226
    Quote Originally Posted by a1ienz View Post
    That may be your problem. Without compression the hard drive is usually not fast enough to get smooth playback. Unless you are using small frame sizes.
    Member
    Nov 2010
    AUS
    Posts
    5
    cheers for the suggestion. Ill try using a codec and will post the results.
    Member
    Nov 2010
    AUS
    Posts
    5
    yep bingo! compression codecs have done the trick. thank you.
  1. Replies: 11
    Last Post: 18th Dec 2012, 10:13
  2. Laggy Blu-ray/MKV playback. Too slow computer?
    By H2SO4JB in forum Newbie / General discussions
    Last Post: 9th Aug 2010, 13:54
  3. Using CoreAVC for mp4/mov playback in WMP
    By mancalledhero in forum Software Playing
    Last Post: 11th Mar 2010, 20:20
  4. vob to mov. Problem with virtualdub codecs
    By jogonan in forum Video Conversion
    Last Post: 24th Nov 2009, 05:29
  5. Sporatic laggy video playback from decent HTPC
    By ChipMcC1 in forum Media Center PC / MediaCenters
    Last Post: 9th Sep 2008, 22:29
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
