Hi,
I'm trying to join 2 ts files which has been created with a DVB encoder. I've been reading a lot of posts about this item.
I've used Tssplitter, Projectx,... The problem is that i can't create a ts file with the same structure than the original.
All softwares that i've used make changes in PES
Is there any idea about it?
Results 1 to 13 of 13
I have done this type of operations successfully with the Transport Stream Packet Editor tool.
Too bad we don't hear much anymore about the development of this nice program.
I'm going to try with TSPE. Ts Muxer and HDTVtoMPEG2 didn't work.
They change the ts structure -
When TSPE joins two files. I get this log:
Warning: PTS wraparound detected. If you want to fix this in the output, retry using the 'zeroPTS' parameter.
Video PTS gap of -5692,3 seconds fixed at 03:09:44 in output file, 0x178.
Section duration is 02:59:23 (269084 video frames)
Average bitrate is 3,82 Mbps
Total time taken 230,08 seconds, write speed 21,3 MB/s
Edit complete: successfully written file with 5142229956 bytes
If I use the'zeroPTS' parameter, the joined file doesn't play audio streams with VLC.
In a second try, I get a joined file without continuity errors.
Which parameters do you change in TSPE? I have disabled all options in Edit /Table Options -
When i use the TSPE tool i don't change much in the settings.
The only thing i enable when pasting/editing different TS parts/recordings is the option: 'Time Code Options/Zero Timecodes?'
If not the playback of the resulting file often can cause problems.
Of course i don't know what type of TS files you are working with.
I also have encountered some (recorded) TS files which TSPE could not handle correctly.
Did you try the older 0.760 version too? -
I use the 0760 version, which is in web. Do you know how can I fix the continuity errors in a ts file?
Thanks for your help -
*** Now that you have read me, do some other things. ***
Scrap your bad recordings, make new ones.
Stream Transport
By Soixante in forum ComputerReplies: 4Last Post: 4th Apr 2014, 05:05 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
Some questions about the Transport Stream.
By Talayero in forum Video ConversionReplies: 4Last Post: 22nd Jul 2008, 18:42 -
MPEG-2 Transport Stream ...
By DeathStalker77 in forum DVB / IPTVReplies: 3Last Post: 26th Feb 2008, 22:22 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06
