    Nov 2010
    India
    Hello there, I'm new here and not sure where to post this question. I'm posting it here anyways, sorry if its posted in wrong section.
    So here's my problem.
    I want to know how and where do I add the command like argument in MeGUI for mkvmerge. I can generally add the command line arguments while merging MKV files with mkvmerge. I'd like to add "--engage no_simpleblocks" command line option to the final phase where MeGUI merges the x264 and M4A Nero AAC audio in MKV container. While merging the tracks in MKV file, I need to add that command line option to get added automatically. I'm sure the people who're following me got the problem correctly. But below is detailed explanation for those who're totally lost with what I'm saying.
    I'm converting the 1.4GB AVI video file with xVID and MP3 streams to MKV with x264 and Nero AAC. So basically what I do is add them to MeGUI, select the profile for both audio and video, and click auto encode. After clicking auto encode, it presents me a new window where I can specify the size or bitrate of the output video. It also allows me to add additional tracks and subtitles, but I can't find the option where it allows me to add the command line options which I can generally add in mkvmerge GUI through Muxing -> Add command line options. Basically the problem is, GOM Player won't show the inbuild subtitles unless I add "--engage no_simpleblocks" while merging the video and audio into MKV container. Its easy to do it through mkvmerge, but my point is, why should I do it again when MeGUI uses mkvmerge anyways in final muxing stage? Only if I could add the command line option in the final stage itself, I won't have to do the muxing phase again for every single encode.
    Thanks for any help, just reply if you're getting what I'm trying to say. I'll explain in more detail if you want.
    Nov 2010
    India
    Bump?
