Somebody has lent me a dvd when I play It In my dvd player I get a picture, background noise everthing works basicly but when the characters speak you can't hear there voices atall was just wondering If anybody new the reason for this.
Cheers![]()
If you hear the background noise in the soundtrack, but not voices, the problem is most likely phase cancellation. Check your speaker wiring and connections.
Great guide. Not. Moving you. And PLEASE try use a better subject then just dvd.
AC3 5.1 audio with no center channel speaker. Reconfigure your audio setup for the speakers you have -- probably stereo (2.0) or stereo plus a sub (2.1). Configure the AC3 decoder to downmix too.
background noise in dvd (from .mov)
By nunsepofa in forum ffmpegX general discussionReplies: 6Last Post: 4th Mar 2012, 20:14 -
Background noise removal - Please help!
By maurof78 in forum AudioReplies: 2Last Post: 3rd Oct 2010, 09:24 -
Background Static Noise..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 00:28 -
Issue: Background noise on DVD following conversion from VCR tape.
By Beech Cricker in forum Newbie / General discussionsReplies: 16Last Post: 6th Feb 2008, 10:37 -
removing background noise on a home made DVD?
By Rudyard in forum AudioReplies: 2Last Post: 22nd Jun 2007, 14:29
