Results 1 to 22 of 22
  1. Vob2MPG crashes when I try to convert toystory 3
    Crash occurs in 3.2 and the previous build
    Any help on fixing this is appreciated.
    Crash Info below:
    Version: VOB2MPG PRO
    Build: 3.2.0000
    Type: System.ArgumentOutOfRangeException
    Source: mscorlib
    Message: Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
    InnerException:
    StackTrace: at System.Collections.CollectionBase.System.Collectio ns.IList.get_Item(Int32 index)
    at VOB2MPG_PRO.IFO.xe2e75cd0c88496d4.get_Item(Int32 index)
    at VOB2MPG_PRO.IFO.x32eac27632acc346.xc5034730a302ffc e()
    at VOB2MPG_PRO.IFO.x32eac27632acc346.xa3a9daebe1fd5c9 3(String xeadccf02f8622700, Boolean xb909d68cec5e9c0b)
    at VOB2MPG_PRO.xfed3de3bc2a8e64d.bOpen_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
    at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you zip up and attach all the *.IFO files associated with this DVD please? I will investigate.
    Nov 2010
    New York
    Having the same issue. Uploading zipped IFO file. Thanks.
    -MAC
    Nov 2010
    Oregon
    This is occuring on ALL new movies. It has happened to me on Karate Kid 2010, Toy Story 3, Oceans etc. It seems to be the new movies...I can't copy any of the new movies. I'm using SlySoft DVD latest version to decode and then use VOB2MPG V3.0 to rip. But all new movies are coming up with this error.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Then just rip the disc to your HDD first and try that. Holy crap people. This isn't brain surgery.
    Nov 2010
    Oregon
    I already tried this (as you say its not brain surgery) and it still does not solve the problem. I take all of movies and put them into digital format so that I never have to take a DVD out to watch it. I can watch straight through my TIVO's by pulling it off the computer. However, no matter whether you rip the TSO files to your HDD using AnyDVD or you decode and try to use VOB2MPG doesn't matter, you will get the same error every time!
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    -MAC
    There is only one file in that zip... surely there are more IFO files for this DVD.
    Nov 2010
    Oregon
    Ok, this is starting to get quite concerning. This program has been flawless for me up until recently. I just bought The Princess and the Frog and I'm getting the same error now that I've gotten on Toy Story 3, Oceans and Karate Kid 2010. Slysoft seems to be decoding them just fine it is just VOBMPG that seems to be having some issues. Here is the error I get:
    Build: 3.0.0131
    Source: mscorlib
    InnerException:
    at VOB2MPG_PRO.xfed3de3bc2a8e64d.xe8f3abafd907f7d4(Ob ject xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    Nov 2010
    Oregon
    Sorry for the multiple posts. I saw that I was not using the lastest version so I installed the latest version. Still having same problem:
    Build: 3.2.0000
    Source: mscorlib
    InnerException:
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you zip up all the IFO files for a DVD which this is happening with then and i will take a look?
    Nov 2010
    Oregon
    Hi Chrissyboy, my apologies but I'm not sure I know how to do this. Can you tell me how to do this using AnyDVD? I ripped the DVD to my hard drive but I just get the Video_TS files.
  12. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    In the VIDEO_TS folder you should see something like:
    If you can't see the file extensions then you can uncheck the Hide Extension option in folder options:
    So what i would like is the IFO files. Alternatively you can send all the files in the VIDEO_TS folder under 1MB.
    Cheers,
    Chris
  13. ChrissyBoy,
    Find below my ifos of Toy Story 3. IFO_09 seems to be the one of the main title.
    This is the first time I use vob2mpg and got the same error. I turned to vobset mode, but no success.
    I extracted the mpg and audio files using makemkv and mkvtoolnix without any problem
    Regards,
  14. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I have a new build to test which should address this. Can one of you PM me to test it please?
    Nov 2010
    Oregon
    Hi Chrissyboy, I'm very sorry I didn't get back to you sooner. I work in the E-Commerce space and the holiday's have been crazy! What does PM mean? I'd be happy to test the build as I have many of the movies this error is occuring on.
  16. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I have sent you a "Private Message"!
  17. I also got this with Toy Story 2 (Australian version) but not Inception. Accessed through the latest AnyDVD. Didn't matter if I ISO-ed it, mounted the ISO and used that - same error. Plays fine in media players.
    Using the free version of VOB2MPG downloaded today.
  18. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I will release a fix for this in the morning.
    Aug 2009
    Spain
    I also got this error with Toy Story 3 (Spanish version) and The Last Airbender (Spanish version).
    Aug 2009
    Spain
  21. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    New release is availiable. Can you confirm this issue is now fixed?
  22. Member
    Aug 2009
    Spain
    New release VOB2MPGPRO V3.2.2000 working O.K. Problem fixed.
