Does anyone know if there is an mp3player in this world that can handle songs in FLAC format with 15000KB - 22000KB with 48KHzI know....it's a lot.
Results 1 to 15 of 15
You can look here and see if any of these devices meet your needs:
http://flac.sourceforge.net/links.html
I don't think support for 48KHz will be a problem but I also don't understand what you mean by "15000KB - 22000KB". -
Basically I have some songs in FLAC format. Each song is 100 megabites, so obviously these song are very high quality.
All I know is that each song has about 15000 or more KB's and they have been ripped from a blu ray disk.
In short, my mp3 player can't play these songs. Do you know an mp3player that can? -
Not many media players play flac. jman98's link is probably the most comprehensive list you'll find.
so multichannel hidef audio? take my advice and convert this to the something like normal stereo - multichannel hidef audio in flac is probably possible only on PC with software player or flexible DSP players (but such player can play native hidef audio - TrueHD Dolby or similar)
There's two universes of audio, the professional audiophile purist, and the portable distributed Internet/YT/iPod type, and they don't mix.
Convert your stuff to 256K 24 bit and enjoy. -
What I mean is that above 256K the quality benefit declines considerably, so why bother unless you're a purist.
One is bit depth, the other is bitrate. Example: 16 bit, 24 bit, 44K, 48K, 128Kbps, 256Kbps.
Yes, but there's a sweet spot and it depends on the individual case.
So long as your conversion is upsampled, you're OK. Upsampling means making a copy at a higher bitrate and bit depth. When you convert, the file is decompressed to .wav or other lossless format, then recompressed to the new format.
In this case, the conversion is "virtually" lossless, but technically lossy. Our hearing is not so great to tell the difference.
DISCLAIMER: Remember, "garbage in, garbage out", conversion or upsampling does not improve a bad recording.
there is no linear relation between kbps and kHz so the question is wrong, what is really worst (ok maybe not worst but it create some difference that create comparison and mathematical models - or very complex and/or not very reliable) that each of us have different "ears" (ears used as a description for general human hearing system) - there is no clear answer for such question and each answer can be wrong except generally more means better but You need good source at the begininng of whole chain - at the end of this chain there is only You and Yours ears and simple like or not like.
24bit/48kHz for DVD
By iker222 in forum Authoring (DVD)Replies: 11Last Post: 3rd Aug 2009, 08:59 -
Convert at Low Bitrates at 48Khz in Stereo
By ashwin.terminator in forum Newbie / General discussionsReplies: 23Last Post: 23rd Jul 2009, 18:13 -
No 48kHz options in MPEG-Layer 3 in VirtualDub and Mod
By ashwin.terminator in forum AudioReplies: 24Last Post: 6th Apr 2009, 15:07 -
32khz mpeg to 48khz how to ?
By Videodream in forum Capturing and VCRReplies: 12Last Post: 4th Aug 2008, 10:11 -
Why was 48khz needed for DVD specs?
By yoda313 in forum AudioReplies: 3Last Post: 7th Jul 2007, 16:57
